should i go obd 1
Old May 3, 2006 | 02:42 PM
Down Shift Motoring's Avatar
Default should i go obd 1
My setup 97 EK coupe
JDM B16 Sir2 with just a AEM intake
current ecu- programmed p72 (vtec at 4700)
Apexi World 2 Exhaust
should i go obd 1??? I heard if I do i will gain tons of power an vtec will rip way harder then it is now. true/not true?
Old May 3, 2006 | 02:43 PM
keemosaki's Avatar
Default Re: should i go obd 1 (ef9typer)
obd1 is easier to tune so Yes
will you gain tons of power from the ecu swap. hellll no. but the potentional is where people switch over... easier to tune with piggy back systems, less codes and bugs (think of windows ... 3.1)
Old May 3, 2006 | 02:50 PM
Default Re: should i go obd 1 (keemosaki)
what about if i run a obd1 skunk 2 ecu? i should run 10 times better then I am right now, because im burning the fuel of a 1.8 in a 1.6 right now, also for some reason it hesistates around 4 grand then pulls at vtec. anything?
Old May 3, 2006 | 03:08 PM
keemosaki's Avatar
make sure you get the right ecu for your motor. b16 requires p30. yes a chipped p30 will help greatly.
Old May 3, 2006 | 03:14 PM
keemosaki's Avatar
actually i did some research and running a p28 chipped to your basemap might yield the best results. but since you got a obdII car, i would assume the p30 would work best.
Old May 3, 2006 | 05:13 PM
thanks i think i am going to go obd 1 with a skunk 2 p28
Old May 3, 2006 | 05:36 PM
cambopheonix56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9typer &raquo;</TD></TR><TR><TD CLASS="quote">what about if i run a obd1 skunk 2 ecu? i should run 10 times better then I am right now, because im burning the fuel of a 1.8 in a 1.6 right now, also for some reason it hesistates around 4 grand then pulls at vtec. anything?</TD></TR></TABLE>
The skunk2 makes you run hella rich. The vtec engagement is way to low for your set up. Thats why you are running rich. Get a custom chipped p28. Set vtec about 5100 rpm. Go to phearable.net.
em1gangsta
18
Mar 28, 2016 05:36 PM
Neptronix
12
Jan 25, 2008 08:06 AM
aznboi_2
Feb 14, 2006 06:40 PM
egmadness
Nov 9, 2005 12:01 PM
ViperRedCRX
Apr 17, 2003 10:38 AM
