95 accord - wiring foglights, help?
i never got done with my wiring, it got rainey and i just unwired them and stopped.
basically, im going to run the wires down the side of the front clip, the right circle on the picture, but im trying to figure out the best way to get my wire from the battery (left) to the hole (right). im stumpted.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap716 »</TD></TR><TR><TD CLASS="quote">i dont understand why you would need that wire from the battery. the harness that i used wasnt hooked up to the battery. so im a little confused. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lxcoupe »</TD></TR><TR><TD CLASS="quote">the lights need power to work...</TD></TR></TABLE>
yes, but most kits, even the generic ones, have a plug that will plug into the underdash fusebox for power, therefore no direct battery connection is needed.
but if you need to go to the battery, go along the firewall towards the bottom then up the framerail then to the foglights. my opinion
Why are you installing foglights when your engine is in such need of attention?
I see a leaking distributor O-ring, leaking valve gover gasket, newer master cylinder with black brake fluid, black clutch fluid, black p/s fluid, corroded battery terminals and probably some other things that I can't see in that picture.
BLKFLSH~ where is your quote when I need it??
Atomic1
Jun 18, 2014 02:45 PM
knightsef-eg
Sep 19, 2008 01:05 PM
2camsaam
Jan 21, 2003 05:45 PM
