Need assistance w/ angel eyes install.
I'm installing the angel eyes projector kit on my EJ.
Problem w/ wiring. The head lights are a male connection and so is the connection to the cars' wiring. How can I get around this?
The kit did come w/ an additional wire harness, its got some relays 2 male connections and 2 female connections, 2 (red) positive wires w/ metal connectors to go to the battery (i'm assuming), and 2 (black) negative wires w/ metal connectors on them to be mounted to the chassis.
Should this harness some how allow me to connect everything successfully? I have tried but could not figure out how.
GDD Member
Re: Need assistance w/ angel eyes install. (2camsaam)
Plug the harness that came with the kit into your new headlights. On your stock harnesses driver's side harness, leave it unplugged from the headlight. Then you can wire your new harness and that's self explanatory, it comes with two grounds and one wire that goes to the positive terminal of your battery. What the new harness does is it allows your high and low beams to stay on simultaneously when you turn your high beams on. As for the rings on your angel eyes, I think they need to be spliced into your parking lights, I don't know though because I've never installed angel eyes.
Please refrain yourself from making future posts about cosmetic items such as lighting and bodykits because honda-tech people will eat you alive.
