Brake or Rotor noise?
Old May 3, 2006 | 12:37 PM
95Integura's Avatar
Default Brake or Rotor noise?
I started having some weird noise come out of my brake and rotor. So I thought it might just be the inside of the wheel ridin on the brake. Which I was wrong. When I spin the rotor it makes this noise. Although I thought it was the brake against the rotor it wasnt. It keeps makin that noise. I just replaced the half-shaft not more than a week ago. I've sat there for the past 30 mins tryin to figure it out. Can anyone help? Anyone have any similar problems?
Old May 3, 2006 | 12:45 PM
xzeus626's Avatar
Default Re: Brake or Rotor noise? (95Integura)
hmmm... maybe the shield is rubbing agains the rotor, perhaps pushing it inwards a little, happened to me before . hope it mite help
Old May 3, 2006 | 12:53 PM
95Integura's Avatar
Default Re: Brake or Rotor noise? (xzeus626)
Actually it was the sheild....lol....thanks man. Im just glad I didnt have to spend like another 100-200bucks more to fix somethin else. haha thanks
Old May 3, 2006 | 12:55 PM
ejmatzell's Avatar
i had this happen about a year ago. I ended up having to replace my rotors (wasn't a bad excuse for some brembo drilled and slotted). are you having squeeking problems? mine started as a light squeek, then turned into a grind. what happened was the rotor warped from exposure to moisture. they had to use a sludge hammer to break the rotor off during installation (while i cringed in the corner). it wasn't that obvious to the naked eye, but just a little warp made the rotor rub on the caliper. this could be your problem?
ejmatzell's Avatar
Default Re: Brake or Rotor noise? (ejmatzell)
well alright then, disregard my rambling! haha
hpilot03
Suspension & Brakes
11
Sep 7, 2015 10:26 AM
Nyleuqcaj1991
Jun 28, 2015 05:11 PM
M4
Jun 9, 2006 10:13 AM
superburner2
Mar 28, 2005 05:05 AM
StewBme
May 27, 2004 01:07 PM
