What ECU to use for a b20z2 into a 99 ex?
Old May 3, 2006 | 12:37 PM
camelian's Avatar
Default What ECU to use for a b20z2 into a 99 ex?
Is there an OBDII ECU I can use with a '00 B20Z2 to have it legally pass emissions in a '99 EX? I remember hearing about the immobilizer with the LS ECU
Old May 3, 2006 | 02:38 PM
t0p_sh0tta's Avatar
Default Re: What ECU to use for a b20z2 into a 99 ex? (camelian)
Don't know the code for the ecu, but there is a 5-speed CRV.
Old May 3, 2006 | 05:08 PM
camelian's Avatar
Will that plug straight in and work with no codes?
Old May 4, 2006 | 11:28 AM
JDM_CivicEG6's Avatar
You can probably use a chipped P75 (OBD2 96-00 LS/GS Integra) or use a P2T (OBD2 99+ Civic Si) ECU.....I am not to sure you are going to be able to pass smog legally regardless of what ECU you use.....good luck...does your EX ECU run the car?
Old May 4, 2006 | 01:41 PM
camelian's Avatar
I'm running a greddy kit with hondata right now and am contemplating returning to just the stock b20. Both the EX ECU as well as the SI ECU throw a CEL b/c of VTEC. The DX ECU will not work either. Does the chipped P75 ecu get rid of the immobilizer?
Is there a way to switch ecu's and run at low boost just for emissions?
Old May 4, 2006 | 01:43 PM
VRD^sam's Avatar
Default Re: (camelian)
Chipped P06
Old May 4, 2006 | 09:41 PM
camelian's Avatar
Isn't P06 OBDI?
Old May 5, 2006 | 02:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camelian &raquo;</TD></TR><TR><TD CLASS="quote">Isn't P06 OBDI?</TD></TR></TABLE>
Yes a PO6 is OBD 1.....the Chipped P75 should get rid of the Immobilizer...
salvagetitlesil
Mar 29, 2012 07:15 AM
anthonyelevenEX
Engine Management and Tuning
Sep 3, 2010 08:24 PM
kyden
Jan 28, 2005 09:31 AM
lsvtec101
Jan 1, 2003 06:39 AM
