87 Accord trans problem
Old May 3, 2006 | 11:36 AM
Rasago's Avatar
Default 87 Accord trans problem
I have an auto trans and it seems to rev and bang into gear. If you shift manually, its fine, just does it in drive. Any help, a sensor, anything?
Old May 3, 2006 | 01:00 PM
Ross 2.0's Avatar
In a Junkyard near you.
Sounds like you need to adjust the trans cable. If it is too tight or loose it will cause shift problems. It sounds like it's too tight, but my experience with those is limited. I'll see if I can blow the dust off of the procedure unless someone can beat me to it.
Also check your fluid. If it's dark and smelly it needs to be changed with Honda ATF-Z1.
bigd85yota
Feb 10, 2020 11:07 AM
tamadrummer1120
Jul 30, 2012 06:40 PM
Gizler00
Mar 25, 2009 07:41 AM
dnc4ever07
Aug 28, 2007 09:02 AM
NMef9
Dec 26, 2006 07:00 AM
