Quick flashing signal
Old May 3, 2006 | 10:04 AM
db8gsr_teg's Avatar
Default Quick flashing signal
Does anyone knows how to make it back to stock cause when it signals, it annoys me to death. I bought the car like this, so i dont know how to make it back to the regular slow signal
Old May 3, 2006 | 10:07 AM
EK k kay's Avatar
Default Re: Quick flashing signal (db8gsr_teg)
Your turn signal bulbs may be on their way out.
Old May 3, 2006 | 10:08 AM
DannyDeuce's Avatar
Its doing that because one of your lights is burnt out.
Check all your lights (headlights, brake lights, rear lights, parking lights) I guarantee that one needs to be replaced.
Replace and you will have regular blinking again.
DAN
Old May 3, 2006 | 02:12 PM
db8gsr_teg's Avatar
i recently replace them and i know how it'll flash when its dead cause i experience it already. The owner before did some kind of **** and made it to signal faster than normal, so i need to make it back to normal cause i think its illegal to have fast blinker in Cali
Old May 3, 2006 | 02:17 PM
Jorsher's Avatar
Isn't there a relay or something that does the blink action? Can't you just replace that.
Old May 3, 2006 | 02:30 PM
egcivicb16's Avatar
you should look at the wiring by your corners up at the front. there is a way to hardwire them so they blink fast. so just look for some wiring that doesnt look normal or is taped up, and just re wire it.
Old May 3, 2006 | 02:36 PM
t0p_sh0tta's Avatar
Default Re: (egcivicb16)
Replace the gay *** relay for the turn signals. A friend of mine did that gayness.
Old May 3, 2006 | 02:46 PM
keemosaki's Avatar
Default Re: (t0p_sh0tta)
another reason they could be doing that is if any of the bulbs are not the correct bulbs for the car... a low amperage bulb will cause them to do that. If you have LED light bulbs, they are extremely low amperage and will also cause them to that. Other then that, some dumbass wired it for the quick blinker which imao is dumb.
Old May 3, 2006 | 02:48 PM
Relic1's Avatar
it can be done two ways, decrease the resistance that the stock flasher relay sees via LED lights or a relay to run the light.
OR install an adjustable flasher or a fast flash blinker relay.
If you don't have LED lights and don't hear extra clicking with the blinkers on. (check outside the car also) Then replace your flasher unit with a stock one and you should be set.
///Nick
Feb 11, 2012 10:10 AM
beginmyhonda
Aug 4, 2011 08:01 AM
PaulMc
Nov 27, 2010 09:29 AM
DC2 Mang
Jul 10, 2006 10:48 AM
1989Prelude
Oct 12, 2005 05:29 PM
