Greddy E-Manage Unit Control Manager
Old May 3, 2006 | 08:06 AM
andyrew500's Avatar
Default Greddy E-Manage Unit Control Manager
"Taken from the Greddy site"
e-Manage is an inexpensive programmable fuel management system that allows you to properly tune your factory fuel system without having to change the entire factory ECU system to an expensive "stand-alone" unit. The e-Manage system is a universal "piggy-back" type unit which taps into most Japanese factory ECU wiring, by utilizing the existing sensors. For Honda VTEC cars you can adjust the VTEC shift point. Additional features are built into the system but are only accessible through the use of the e0-1 programmer or our PC-Windows based "e-Manage Support Tool" communication software (Please see our Authorized GReddy Support Dealers for more information). <U>There is a 16x16 airflow adjustment map, larger main injector correction adjustment, upgrade air flow meter adjustment, boost limiter cut, anti-engine stall, VTEC-fuel adjustment, real-time map trace, real-time display, real-time communication and basic Data-logging. </U>With the use of our "Optional Injector Harness" and the software, the unit has the ability to control an additional 16x16 injector duty cycle map and the controls for adding up to 2 additional sub-injectors. If the "Optional Ignition Harness" and the software are used the unit has the ability to control a 16x16 ignition timing map. All of the above maps can also be map-traced in real-time as well. If the factory range of map or airflow meter is surpassed, you can incorporate our "Optional GReddy Pressure Sensor and Pressure Harness" to set larger scales of adjustment. All installation and tuning should only be made by a trained technician with proper air/fuel monitoring tools. (Some functions may not be compatible with some applications.)
I have a fully loaded kit with: Main unit, Main harness, Ignition and Injection Harnesses, 3- bar boost sensor w/harness, PC software supoort tool, and Unit-PC link cable. $450.00
Old May 28, 2006 | 03:13 PM
andyrew500's Avatar
Default Re: Greddy E-Manage Unit Control Manager (andyrew500)
bump
Old Aug 20, 2006 | 01:03 AM
L33TsAbabyEater's Avatar
Bump for a great system...
Old Aug 20, 2006 | 08:47 AM
Rennen's Avatar
would you sell just the support tool?
Excelerate
Jan 19, 2006 11:41 AM
JunIntegra
Oct 10, 2004 10:04 AM
Jon5240
May 18, 2003 09:06 PM
FabulousSi
Apr 15, 2003 06:32 AM
Duck Sauce
Nov 3, 2002 06:55 PM
