h22 in eg with AC
keep your D series compressor.. and go with the hcp egh22 mount kit.. that comes with a bracket for the D series compressor to run on your h22..
if havent found an H22 yet.. lmk.. i got one running and all in my integra. complete.. with mount kit..the only thing its missing is that a/c bracket
I have a 95 ex coupe and the engine is setting close the firewall and with the hcp bracket i still don't have room to put my condensor in my alternator would be snugged against the condensor...do you have to cut on the radiator support and move lines?
prolly best route would be to use a 94-up condensor since it sits in front of the radiator. It would allow for enough clearance of other things. Basically just use a complete AC system from a DC chassis. Might have to massage some lines around the alternator a little bit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6madness »</TD></TR><TR><TD CLASS="quote">quick question, if i swap a h22 into my eg what must i do to retain my AC?</TD></TR></TABLE>
It's very tough. Most people just don't. Not only can you only use the stock header, but everything else is pretty much a bitch.
