What head should I change to? 97 accord EX
Old Apr 9, 2002 | 05:43 PM
1997Accord's Avatar
Default What head should I change to? 97 accord EX
What is a good head I can change my 97 accord Ex 4cyl to? I need more power.
Old Apr 9, 2002 | 05:50 PM
p0pe's Avatar
Default Re: What head should I change to? 97 accord EX (1997Accord)
I need some good head too. haha, sorry I could't help you...
[Modified by p0pe, 8:51 PM 4/9/2002]
Old Apr 9, 2002 | 06:24 PM
Kazmans94cord's Avatar
uhh i dont think you can change the head on a f22b1
Old Apr 9, 2002 | 07:28 PM
Nick H's Avatar
New User
Default Re: What head should I change to? 97 accord EX (kazmans94cord)
yeah...there isn't a head that'll fit our cars...the dohc heads won't fit on there because they are all off of a different series of engines...so your sohc vtec head is probably the best for what you have...
[Modified by nickh2k1, 11:31 PM 4/9/2002]
Old Apr 9, 2002 | 07:30 PM
Nick H's Avatar
New User
Default Re: What head should I change to? 97 accord EX (nickh2k1)
p.s. if you want more power just get an h22 (prelude)...that is probably your best bet or you could go with an h23 (non vtec) and put a turbo on it (this is pricey however)...the stock accord engines are not meant for speed unless of course you have the big ol' V6...
Old Apr 9, 2002 | 07:33 PM
Conechaser's Avatar
Yeah, thats why i was hitting the same speeds @ VIR as GSRs
Old Apr 10, 2002 | 09:03 AM
Stew Pidasso's Avatar
https://honda-tech.com/zerothread?id=158438 Check out my post at the bottom of the page.This seems to be your best bet and believe me I've searched.
Old Apr 10, 2002 | 09:06 AM
Brandon's Avatar
Life is Suffering
If you are sadistic, then try to bolt on an S2000 head. And to those of you who doubt the F-series of engines, the greatest engine in the world is an F-series.
[Modified by vtec2k2, 1:07 PM 4/10/2002]
Old Apr 10, 2002 | 09:09 AM
4doorH22's Avatar
Default Re: What head should I change to? 97 accord EX (vtec2k2)
Unfortunately the great F motors like the F20B in the Sir-T and the F20C in the S2000 do not use the same block as in the F22/23 Accords.
Old Apr 10, 2002 | 09:12 AM
Brandon's Avatar
Life is Suffering
Default Re: What head should I change to? 97 accord EX (4doorH22)
Actually, the only reason they would be an F-series is that they share the same basic block design. The only differences are the oil passages, which could be re-routed with a custom block extension.
Old Apr 10, 2002 | 09:17 AM
Nick M's Avatar
Same basic design, but its not the same block.
Old Apr 10, 2002 | 09:18 AM
Accord94DX's Avatar
H23A1 OWNZ.
Old Apr 10, 2002 | 09:25 AM
H23 Power's Avatar
Default Re: What head should I change to? 97 accord EX (Accord94DX)
you could put on a F23 head...they re worked the intake and exhaust ports completely...probably flows better...but not worth the money
Old Apr 10, 2002 | 09:26 AM
4doorH22's Avatar
Honda motor codes do not relate to the block. The F20B is a H22 block with destroked crank. The F20C is entirely a new block, probably based on the new K series engines.
Old Apr 10, 2002 | 09:27 AM
H23 Power's Avatar
h and f series blocks are fairly similar
Old Apr 10, 2002 | 09:33 AM
4doorH22's Avatar
Default Re: What head should I change to? 97 accord EX (01GSR)
Actually, every inline 4 block in the world is fairly similar!
Old Apr 10, 2002 | 09:34 AM
Brandon's Avatar
Life is Suffering
The F20C is not a new block, and it definitely is not a K-series. The K-series is not like any other Honda motor, because it spins the other way. The K-series uses a similar block because the F-series has a very robust block.
Old Apr 10, 2002 | 09:40 AM
4doorH22's Avatar
The F20C in the S2000 was Honda's first clockwise spinning engine, just like the new K-series!!!!!!!!!!!
Old Apr 10, 2002 | 09:45 AM
Brandon's Avatar
Life is Suffering
Check the palcement of the intake and exhaust when you look at the engine. They are still on the same side as the other F-series motors in relation to the tranny. Which means can't spin backwards.
is this guy the CEO of honda or what? comon...
Old Apr 10, 2002 | 09:48 AM
Brandon's Avatar
Life is Suffering
No, but I have studied Hondas for the past 6 years. I also interned at the Honda plant in Marysville, OH last summer. I learned a lot there. Too much.
4doorH22's Avatar
Whoa dude. The F20C in the S2000 is a longitudinally mounted rear-driver. Every longitudinally mounted rear-driver in the world has a clockwise-spinning engine. It is a fact that the F20C was the first Honda engine to ever spin clockwise.
Old Apr 10, 2002 | 09:52 AM
Brandon's Avatar
Life is Suffering
Stop now or forever hold your tongue. As proof that not every long mounted engine is clockwise, my 924 turbo was made with an Audi engine. That engine spins counter-clockwise, even though it is a long mounted rear driver.
Old Apr 10, 2002 | 09:56 AM
SOHCArchangel's Avatar
Old Apr 10, 2002 | 09:58 AM
4doorH22's Avatar
I was just guessing that every longitudinally mounted engine rear drive car had a clockwise spinning engine. But I do know for a fact the F20C spins clockwise, unlike any previous Honda motor which spun counter-clockwise.
