Wire Harness Help (B18C1 in 92 Dx Bubble)
Old May 3, 2006 | 06:22 AM
drshottest718's Avatar
Default Wire Harness Help (B18C1 in 92 Dx Bubble)
The GSR in my EG started up fine but it's throwing a few codes. I should have the mess sorted out quickly though. Anyway at the passenger side shock tower one of my plugs isnt connected to anything. I dont see anywhere that I can connect it either. Can someone help me out here. Is this ok? BTW I'm using OBD2 harness, dizzy, etc. But the car is OBD1.
all of the other clips connected. take a look.
Old May 3, 2006 | 06:56 AM
flatblack-h22's Avatar
Default Re: Wire Harness Help (drshottest718)
nothing, i remember having one plug that was not connected
Old May 3, 2006 | 07:08 AM
Slamaccord's Avatar
That plug I believe goes to the evap canister which your civic does not have.
Just leave it unpluged you will be fine.
Did you run the codes ?
Old May 3, 2006 | 07:42 AM
Slopoke's Avatar
You're '92 civic is prewired for vtec, but did you run the wires for Knock sensor and IABs?
Old May 16, 2006 | 06:40 PM
crxcel's Avatar
Default Re: (Slopoke)
im doing same swap this weekend, need help as to where to Wire IAB in..plz help
Old May 16, 2006 | 08:41 PM
axtran's Avatar
passenger side plug? looks like the map sensor plug. you may have it as extra.
make sure u get that knock hooked up
if the motor and ecu and harness is OBD1, IAB is easy - use the evap purge wire and move A20 to A17 on the ECU.
OBD2, a little different move A20 to A17 and find a ground for the 2nd wire.
Old May 16, 2006 | 08:42 PM
axtran's Avatar
and by extra, i meant that my map sensor came out of the firewall.
Old May 16, 2006 | 08:52 PM
hatchi's Avatar
that extra harness is there and it doesnt go anywhere coz your car dont have it since its obd1. Your tach will not work also and you need to run a wire from distributor to driverside wire and tap it in
Old Oct 30, 2006 | 06:27 PM
joz_mendoz's Avatar
Default Re: (crxcel) need help with making a usdm eg harness work with a jdm b-18 application
maybe you can help me, im doing a jdm b-18 swap on a 95 eg hatch and im basically finished all i need to know is if im using the original harness from the eg and use it for my b-18 what sensors will i have to re-wire in order for it too work and which plugs do i salvage from b-18 harness please help screen name joz_mendoz
Old Oct 30, 2006 | 06:33 PM
joz_mendoz's Avatar
maybe you can help me, im doing a jdm b-18 swap on a 95 eg hatch and im basically finished all i need to know is if im using the original harness from the eg and use it for my b-18 what sensors will i have to re-wire in order for it too work and which plugs do i salvage from b-18 harness please help please e-mail me some info joz_mendoz@yahoo.com
Old Oct 30, 2006 | 08:12 PM
92J-SpecHatch's Avatar
Default Re: (joz_mendoz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">that extra harness is there and it doesnt go anywhere coz your car dont have it since its obd1. Your tach will not work also and you need to run a wire from distributor to driverside wire and tap it in</TD></TR></TABLE>
your tach should work fine i did the same swap and i just left it unplugged no CELs and tach an perfect...
kevinoneill
Dec 19, 2010 12:20 PM
bmoney
Aug 13, 2006 01:36 PM
quicksilverej6
Mar 22, 2006 05:48 PM
A.E Motoring
11
Jan 8, 2006 09:05 PM
