symptoms of a bad tranny
Old May 3, 2006 | 05:44 AM
jeremypr's Avatar
Default symptoms of a bad tranny
i have a 96 acura integra LS 98 k automatic.
My question is what is or are the symptoms of a bad transmission in an automatic? when i accelerate it delays for a second, but i think cause the older is getting older...and the pickup on it and performance is not up to what it used to be, can someone an expert or mechanic advise me some symptoms of a tranny going bad?
thanks
Old May 3, 2006 | 06:49 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: symptoms of a bad tranny (jeremypr)
Fluid with a burned smell is never good. Do the clutches slip during gear changes?
Old May 3, 2006 | 07:18 AM
DC2 Mang's Avatar
rough up and down shifts are symptoms, also and whining it makes while driving
it could be a slipping clutch because that is a common problem with honda's
Old May 4, 2006 | 01:31 PM
jeremypr's Avatar
Default Re: symptoms of a bad tranny (JDMdc2lsVtec)
when you say rough or slipping what do you mean, remembe I drive automatic, when i accelerate...and i can feel it kicking into another gear, it kinda...isn't as smooth as I anticipate..it doesnt necessarily rattle or jump real fast, but it just isnt a smooth transition, would your car stall if you have a bad tranny?
Old May 4, 2006 | 01:53 PM
PushinRedline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec &raquo;</TD></TR><TR><TD CLASS="quote">rough up and down shifts are symptoms, also and whining it makes while driving
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Fluid with a burned smell is never good. Do the clutches slip during gear changes?</TD></TR></TABLE>
...he said it's an "AUTOMATIC"...in case you two didn't see that ..it's an AUTOMATIC AUTOMATIC AUTOMATIC AUTOMATIC...and we all know automatics don't come with clutches...
..juz trying to get things straight here....
Old May 4, 2006 | 03:44 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: symptoms of a bad tranny (PushinRedline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PushinRedline &raquo;</TD></TR><TR><TD CLASS="quote">
..juz trying to get things straight here.... </TD></TR></TABLE>
Would you care to explain what is in the picture?
http://www.acuraparts247.com/p...ch=no
Automatic transmissions have many clutches, which can slip when failing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeremypr &raquo;</TD></TR><TR><TD CLASS="quote">when you say rough or slipping what do you mean, remembe I drive automatic, when i accelerate...and i can feel it kicking into another gear, it kinda...isn't as smooth as I anticipate..it doesnt necessarily rattle or jump real fast, but it just isnt a smooth transition, would your car stall if you have a bad tranny?</TD></TR></TABLE>
Slipping clutches will rev briefly and then drop RPM as the gear engages more slowly than is normal. If I recall correctly, the ECU controls gear changes in your AT.
Old May 4, 2006 | 04:08 PM
Nighthawk R18's Avatar
every car has a clutch
Old May 4, 2006 | 04:11 PM
Default Re: symptoms of a bad tranny (VTEC Genetics)
here's a link to back up what i said
http://auto.howstuffworks.com/clutch.htm
Old May 4, 2006 | 05:11 PM
JThrasher79's Avatar
when was the last time the fluid was changed? if its been a while i like redline ATF and Lucas fluid
Old May 4, 2006 | 09:23 PM
Naruto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PushinRedline &raquo;</TD></TR><TR><TD CLASS="quote">...and we all know automatics don't come with clutches...
Really?? I could have sworn automatic transmissions HAVE clutches inside them.
Giving you the benefit of the doubt here, I'm assuming you mean "cars that came with automatic transmissions did not come with a clutch PEDAL."
Old May 5, 2006 | 01:05 PM
morocco's Avatar
Default Re: symptoms of a bad tranny (Naruto)
Your transmission shouldnt be bad at 98k. Someone on HT told me this and it works, take the solenoids in the tranny out and clean them. I would have a tranny place go and clean them rather than you doing it yourself but it will shift much nicer. Also, have the tranny fluid completely changed. If the tranny continues to shift hard, gets stuck in a gear, or shifts really loosely and sometimes goes into neutral its bad.
Old May 5, 2006 | 01:07 PM
cm zak's Avatar
torque converter anyone?
Old May 5, 2006 | 01:25 PM
VHOA's Avatar
Default Re: (cm zak)
..juz trying to get things straight here.... </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
Slipping clutches will rev briefly and then drop RPM as the gear engages more slowly than is normal. If I recall correctly, the ECU controls gear changes in your AT.</TD></TR></TABLE>
Thats some classic ownage and thats what i like to see PWNED!!!!!
Old May 5, 2006 | 06:23 PM
SlamminS85's Avatar
Default Re: (VHOA)
exactly, but only in hondas, american cars have planetary gears, no internal clutches... except on some that have a clutch on the reverse
Old May 10, 2006 | 09:35 AM
jeremypr's Avatar
Default Re: (SlamminS85)
What about the Vacumn Modulator should I get a check up on that?
ILS_09
Jan 26, 2009 04:59 PM
Markis.
Nov 29, 2004 03:03 PM
crx_88_si
Jul 27, 2004 08:32 AM
