H23 throtle body and air manifold onto F22B2
Old May 3, 2006 | 02:25 AM
lc4132's Avatar
Default H23 throtle body and air manifold onto F22B2
I need some advice.
How hard would it be to swap a H23 throtle body and air manifold onto a F22B2 block
Non v tech autoL95 accord
Old May 3, 2006 | 03:10 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: H23 throtle body and air manifold onto F22B2 (lc4132)
Just take a look at this thread. Yes, it's for a F22B1 (94-97 2.2L SOHC VTEC) but just firgure you'll need to do everything but the cutting of the flange since the F22B2 head doesn't have the VTEC Solenoid. Now I'm not exactly sure about not having to cut the flange but it would only make sence that you wouldn't have to. But other than that, everything else should be the same as the H23 IM onto the F22B1 head.
Old May 3, 2006 | 03:37 AM
lc4132's Avatar
What would you think about getting the air man and thr body from a salvage yard
And what vehicle should I request it to come off of
?yr prelude?
Old May 3, 2006 | 03:50 AM
H-T Order of Merit
coming from a junkyard isn't a problem, just make sure everything is there and in good condition.
The car your going to be looking for is a 92-96 Prelude Si with the 2.3L DOHC non-VTEC. The 2.2L DOHC VTEC motors (H22A) are not compatible with the F22Bx heads.
Old May 3, 2006 | 06:01 AM
lc4132's Avatar
Default Re: H23 throtle body and air manifold onto F22B2 (TouringAccord)
Thank you very much
Old May 3, 2006 | 06:14 AM
H-T Order of Merit
yep, np.
Did you get my PM?
Old May 3, 2006 | 06:21 AM
lc4132's Avatar
PM???
Old May 3, 2006 | 06:40 AM
H-T Order of Merit
or IM, same thing.
Go to your "My Profile" at the top, four links to the left of the "Search" feature. Click it to open it, then go to "Instant Measage History". It'll be in there.
It'll pop up when you refresh the H-T page, when you post or when you open a thread, ect. But if your using pop-up blockers, it'll get blocked.
Old May 3, 2006 | 07:51 AM
lc4132's Avatar
I am using a mobile com device and the damb thing doesn't let me I'm or open them
You can email dirrect to
lclark@tmail.com
Old May 3, 2006 | 08:13 AM
H-T Order of Merit
ah, ok. I'll go ahead and email what I IM'd you later.
IndecentXxXposur
May 22, 2009 01:00 PM
prelude_93vtec
Dec 1, 2008 09:39 AM
lc4132
Oct 1, 2006 03:30 PM
ProjectLudeSiR
May 19, 2004 07:01 PM
