Suspension & Brakes Theory, alignment, spring rates....
How To: LSD Traction Bar Install (EF)
Old May 3, 2006 | 12:30 AM
DualCamDan's Avatar
Default How To: LSD Traction Bar Install (EF)
So i've had these bars sitting around for long enough, i figured since it was a nice day out i'd get them out of the kitchen, lol. They are the Lsd/Jk Motorsports traction bars. They are very strong and not to hard on the wallet. I picked mine up about 3 months ago, but i wanna say they are going for abour $275 shipped now.
Well here ya go!
Drain your coolant...
when your dont w/ that take out your radiator
You can start unbolting
I chose to start w/ the radious arms 1st
I used a rench (14m)
And another view
Then the crossmember
I used air tools ( 17m)
You'll have this...
And under the car
After that i took of my tow hooks, just the 3 bolts (14m)
Next you'l have to cut off the factory rad. mounts on the LSD TB's they have new mounting points, others may require you to re-use them
And now off
Now you bolt up your new bar to the tow hook blots
Put your radious arms on and start bolting
This is how the RA brackets go!
And they're on!
Now all you have left to do is install the radiator... I put together a "make shift" bracket till i have the materals to do something nicer...
Now fill your coolant, adjust your radious arms a bit and hit the road!
P.s. You might want to get a wheel alignment Soon!
Old May 3, 2006 | 01:51 AM
turboDeznutz's Avatar
Default Re: How To: LSD Traction Bar Install (DualCamDan)
nice install have u tested those bad boys out
Old May 3, 2006 | 09:13 PM
VRD^don's Avatar
Default Re: How To: LSD Traction Bar Install (EK_UR*)
nice write up y0
Old May 3, 2006 | 09:52 PM
DualCamDan's Avatar
i've launched it about 3-4 times, between 3-5k, nothing crazy, i have 1g azenis on Hx's and had no wheel hop what so ever! they spun a bit and them i was gone! i've taken a few tight turns, but nothing crazy, i want to make sure i TQ'd everything down enough before i go nuts with it, lol
for LSD traction bars!
Old May 3, 2006 | 11:03 PM
LSD Motorsports's Avatar
Old May 3, 2006 | 11:06 PM
Default Re: How To: LSD Traction Bar Install (LSD Motorsports)
have u got an alingment yet? does it make a huge difrence i installed mine but i havent got an alingment..
Old May 4, 2006 | 12:54 AM
DualCamDan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_UR* &raquo;</TD></TR><TR><TD CLASS="quote">have u got an alingment yet? does it make a huge difrence i installed mine but i havent got an alingment..</TD></TR></TABLE>
not yet, lol. hopefully in about a week i will have!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSD Motorsports &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
thank you sir!
Old May 4, 2006 | 11:50 AM
looks good man, glad to see them installed.
Old May 5, 2006 | 07:24 AM
Danronian's Avatar
Very nice. My friend is getting one for his Rex as soon as he has the funds. The rad placement looks very nice with this.
Old Jun 6, 2006 | 09:20 PM
sohcvtec1995's Avatar
do you have a FMIC on a N/A car?
Old Jun 7, 2006 | 08:30 AM
Tuesday Club's Avatar
Default Re: (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">do you have a FMIC on a N/A car?</TD></TR></TABLE>
Old Sep 2, 2006 | 03:20 PM
MatrixGSR's Avatar
I don't see the need for an alignment. It's not like you're putting any stretch or pull on the camber angles or anything like that...
Old Sep 3, 2006 | 03:18 AM
DualCamDan's Avatar
Default Re: (Tuesday Club)
yes and no, lol. i had a front mount on my boosted crx in witch i had just finished swapping the motor and was working on welding up my IC piping and DP at the same time as the install! the car is boosted now! lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MatrixGSR &raquo;</TD></TR><TR><TD CLASS="quote">I don't see the need for an alignment. It's not like you're putting any stretch or pull on the camber angles or anything like that...</TD></TR></TABLE>
B4 the traction bars my steering wheel was almost straight, now it's cocked to the side. by adjusting the radious arms t will change you settings, in whitch you will need and anignment!
Shut It Fool
Transmission & Drivetrain
18
Jan 26, 2011 04:51 PM
DualCamDan
49
May 20, 2006 08:18 AM
rkrone
Apr 22, 2006 12:37 PM
azb20vtec
Jun 13, 2005 05:06 PM
d_mina
Sep 18, 2003 12:04 PM
