I screwed up my paint pretty bad, any tips?
Old May 2, 2006 | 07:46 PM
O16581724 5 2 5's Avatar
Default I screwed up my paint pretty bad, any tips?
I did the new roller paint technique that's getting popular, unfortionately, i mixed it with Acetone like the can said insted of Mineral Spirits like the online How-To said because the can said "Do not use Mineral Spirits". Okay, mix it, put it on, looks great, come back 30 hours later, paint feels like rubber, i found out that's how it's supposed to dry, Mineral Spirits make it harden.
I need tips how to get this off, i put on aircraft remover and yeah, it removed it, but it made the paint terrible underneith, some places ate through the clear, others didn't even eat through the new paint i put on. It's rutted bad and going to be nearly impossible to get straight again, i spent about an hour on a 2"x12" area to get it looking okay again.
Old May 2, 2006 | 08:05 PM
Nevets's Avatar
Default Re: I screwed up my paint pretty bad, any tips? (O16581724 5 2 5)
Burn it . JK Good luck man. Should have followed the how-to directions.
Old May 2, 2006 | 08:42 PM
Default Re: I screwed up my paint pretty bad, any tips? (DA-Steve)
Yeah...i know now. =\
It said on the can to use Acetone, i thought the can would know better.
Old May 2, 2006 | 08:51 PM
dumped_ej1
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O16581724 5 2 5 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah...i know now. =\
It said on the can to use Acetone, i thought the can would know better.</TD></TR></TABLE>
ever heard of trial and error? apparently this has happened before, hence the reason the how-to's say dont use acetone
Old May 2, 2006 | 08:52 PM
Default Re: I screwed up my paint pretty bad, any tips? (dumped_ej1)
I didn't see where it said not to use Acetone...
What how-to did you see? Assuming you did and it said not to...
Old May 2, 2006 | 08:58 PM
dumped_ej1
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O16581724 5 2 5 &raquo;</TD></TR><TR><TD CLASS="quote">I didn't see where it said not to use Acetone...
What how-to did you see? Assuming you did and it said not to...</TD></TR></TABLE>
ive seen a couple that advise using mineral spirits and NOT acetone.
Old May 2, 2006 | 09:24 PM
VTEC_Club's Avatar
That's crazy. Just do it right next time. Forget all that low budget $50 paint job crap. Its going to cost you more than what you bargain for. Just use paint remover. Your paint is done with.
Old May 2, 2006 | 09:37 PM
Default Re: I screwed up my paint pretty bad, any tips? (VTEC_Club)
Oh, i know it's ruined, i just want some tips for making my body straight again, air craft remover removes it retarded unevenly and it's going to take literally a week to get my body straight again scraping the paint off and sanding it.
Old May 2, 2006 | 09:39 PM
VTEC_Club's Avatar
try using acetone to remove it. thats how I get primer off.
Post some pics, it can't be that bad??
Old May 3, 2006 | 12:00 AM
Oh it is, i think i'm going to sand blast it actually, i think i found someone with access to one.
Old May 3, 2006 | 12:07 AM
Elwuudz's Avatar
i've been working my body... of my del sol for about a month now.
I would suggest taking a really abbrassive pad and an electric RO 5'' sander and take all the paint off until u hit metal. That is the best way to prep for paint.
Acetone... i used that to remove oil and grease from my engine tranny and valve cover b4 cleaning... acetone will not speed up the process ofpaint removal ne more than a good electric or AP sander with dust collection.
Remeber to use a self etching primer b4 paint and dont forget to wetsand the clearcoat
The curing of the paint and the prep work will make or break your job!!
Old May 3, 2006 | 12:09 AM
Default Re: I screwed up my paint pretty bad, any tips? (Elwuudz)
A month, forget that, i just want it to look decent, not good.
I asked someone after posting this, he suggested soaking a rag in the Acetone and laying it on it. If all else fails, bare metal like you suggested, i just don't want rust problems.
Old May 3, 2006 | 03:27 AM
kidkombo's Avatar
take lacquer thinner and soak a rag...and just wipe all that **** off...itll take off your stock paint too LOL....why dont you just take it in the *** and take it to maaco for a quick fix...hahah sorry
Old May 3, 2006 | 03:35 AM
19civic93's Avatar
Default Re: I screwed up my paint pretty bad, any tips? (kidkombo)
use fast thinner or lacquer thinner. it won't hurt your clear coat as long as you don't leave it on too long. like kidkombo said soak a rag and wipe. aircraft paint stripper is used to go to bare metal.
Old May 11, 2006 | 12:21 AM
Elwuudz's Avatar
invest in some PPG paint with acrlyic hardener and use plenty of clear cote
paint and extras cost you about 400$ no more no less
Old May 11, 2006 | 12:34 AM
I think i've taken care of it, i didn't even need to strip it, it's just that the paint needed a week to dry and reacts with spray paint.
Old May 11, 2006 | 12:40 AM
kidkombo's Avatar
i wanna see pics of the results...just curious..
Old May 11, 2006 | 01:00 AM
217sportcompacts's Avatar
take it to a body shop or start learning fast
GoLowDrew
Paint and Body
May 16, 2010 05:21 AM
sawjai526
Paint and Body
Sep 7, 2008 10:13 AM
ontheline
Paint and Body
16
Mar 9, 2008 07:08 PM
timmybilt
Paint and Body
Aug 20, 2007 04:26 PM
huntarrr
Sep 21, 2004 11:30 AM
