$1500 left....what to buy?
Old May 2, 2006 | 03:37 PM
B16A3Civic*Eg's Avatar
Default $1500 left....what to buy?
im doing a b16 swap in my eg and i have about 1500 left. What parts should i get for it? I also want to know if i could rave a ser spec-v with confidence assuming i do a set up suggested by anyone.
Old May 2, 2006 | 03:41 PM
axtran's Avatar
ain't ur name H22 civic? :-P
i just got convinced into GSR-ing...
Old May 2, 2006 | 03:45 PM
civic_driver's Avatar
make sure to tune it then get whatever parts you can for a turbo kit.. and send me a 100 dolla bill to help out with the groceries for next month.. this is no joke so don't laugh
Old May 2, 2006 | 03:49 PM
hatch34's Avatar
Default Re: (civic_driver)
i say get a GSR rather then the b16 and then do all the basic bolt ons
ZCVTEC-SOHC's Avatar
From: PhantomGrayEH2, CA Where Gay Arnold Rules, USA
Default Re: $1500 left....what to buy? (H22*Civic*)
Sentra SE-"R" Spec V's are a joke. If you're running a stock B16 on an "EG" it should be no problem. Take it to the track.
Old May 2, 2006 | 03:56 PM
Default Re: (axtran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axtran &raquo;</TD></TR><TR><TD CLASS="quote">ain't ur name H22 civic? :-P
i just got convinced into GSR-ing...</TD></TR></TABLE>
Yes i had everything lined up for it. But im not gonna deal with the hastles of everything. I know it probably makes me look stupid or whatever but i just changed my mind thats all. Sorry for the inconvenience for you to have to read my name.
Old May 2, 2006 | 03:58 PM
Default Re: $1500 left....what to buy? (d15singlecammer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15singlecammer &raquo;</TD></TR><TR><TD CLASS="quote">Sentra SE-"R" Spec V's are a joke. If you're running a stock B16 on an "EG" it should be no problem. Take it to the track.
What should i do with the 1500. I'm asking specifically you because you're the only one that seems to care about my question. You know why does every body have to critisize? Whatever. Thank you very much for your honest opinion. But again...what to do with that 1500?
Old May 2, 2006 | 04:02 PM
schardbody's Avatar
save it for a tranny when the B16 synchros are gone, or if its burning a hole in your pocket boost it, $1000 in parts + $500+ tuning.
Old May 2, 2006 | 04:10 PM
EJ8 GSR-T's Avatar
without getting very serious its hard to spend exactly 1500....i mean do the bolt ons obviously....exhaust, headers, intake, maybe intake manifold, but if you get picky like into cam gears and that kinda junk youll blow a lota money for not to much gain. To get serious you can look into a mild boost, i am guessing you want the motor to last a while so look into a t3 super 60 on like 6 psi, itl be difficult to do it right on that price, but its a option.
Old May 2, 2006 | 04:16 PM
sicky's Avatar
grammer nawzi
Default Re: $1500 left....what to buy? (userdead626)
CTR/ITR cams, springs, retainers, I/H/E, intake manifold, and then pocket the rest for future break downs.
Old May 2, 2006 | 04:19 PM
EJ8 GSR-T's Avatar
Default Re: $1500 left....what to buy? (sicky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky &raquo;</TD></TR><TR><TD CLASS="quote">CTR/ITR cams, springs, retainers, I/H/E, intake manifold, and then pocket the rest for future break downs.</TD></TR></TABLE>
cams springs and retainers will run him probably close to a grand alone....if he has it done properly and tuned for it, and that will net him very few ponies for that $$$
Old May 2, 2006 | 04:42 PM
thehatchninja's Avatar
piece together a turbo setup.
Old May 2, 2006 | 04:57 PM
TurboCoop's Avatar
Default Re: (thehatchninja)
SER Spec-Vs are the biggest POS ripoff "performance" car you can buy. Period. If you take the time to research about them you will find this to be 100% true. Thier trannys are complete ****, the motors arent much better and everything else is just **** made to look nice. Im not just bandwagoning either, my friend had an 03 and his tranny went out, after he got a new one his motor blew 2 weeks later. It was partly his fault for modifying it (I/H/E...) but any other motor could have lasted longer. Dont waste your money, if you want a Nissan get a 240.
TurboCoop's Avatar
PS- you can change your H-T name in your profile
Old May 2, 2006 | 04:58 PM
Syndacate's Avatar
TURBO!!!
Old May 2, 2006 | 05:03 PM
EX-T's Avatar
Default Re: (TurboCoop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCoop &raquo;</TD></TR><TR><TD CLASS="quote">SER Spec-Vs are the biggest POS ripoff "performance" car you can buy. Period. If you take the time to research about them you will find this to be 100% true. Thier trannys are complete ****, the motors arent much better and everything else is just **** made to look nice. Im not just bandwagoning either, my friend had an 03 and his tranny went out, after he got a new one his motor blew 2 weeks later. It was partly his fault for modifying it (I/H/E...) but any other motor could have lasted longer. Dont waste your money, if you want a Nissan get a 240.</TD></TR></TABLE>
He didn't say he was gonna get a SpecV he was asking if he could beat one with confidence. I also disagree with you saying that POSs b/c I have a buddy runnin' 15 pounds of boost on a stock bottom end with a good SAFC hack without any problems.
For the OP, I would boost it. It will be the best money you've ever spent and you can find a used GReddy turbo kit for around $1500 with everything you'll ever need!!!!!!!
Old May 2, 2006 | 05:05 PM
JDM Vision's Avatar
Default Re: (EX-T)
2.0 b16 use the 1500 to do that
EX-T's Avatar
Default Re: (JDM Vision)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Vision &raquo;</TD></TR><TR><TD CLASS="quote">2.0 b16 use the 1500 to do that</TD></TR></TABLE>
You also can't go wrong with more displacement!
Old May 2, 2006 | 05:51 PM
95DxSi-R2
Guest
Posts: n/a
boost it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
if i had the money thats what i would do. i can't wait to go turbo
first it was i can't wait to get a swap, now it's i can't wait to go turbo
eg2phosizzle's Avatar
i would piece together a turbo kit with that money...piece it together dont buy a kit...kits are overated...run moderate boost and you'll blow away more than spec v's...my .02
Old May 2, 2006 | 06:14 PM
Default Re: (eg2phosizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg2phosizzle &raquo;</TD></TR><TR><TD CLASS="quote">i would piece together a turbo kit with that money...piece it together dont buy a kit...kits are overated...run moderate boost and you'll blow away more than spec v's...my .02</TD></TR></TABLE>
Any suggestions on what i should get for parts...if anyone could write a list that would be good!
Old May 2, 2006 | 06:16 PM
DB1_559's Avatar
huh sell it and do a ls/vtec cause really i think b16's are a joke
Old May 2, 2006 | 06:22 PM
PhatBoy5015's Avatar
240sx's are good, but so is a Spec-V. They are pretty quick, cheap, and reliable. Any car from the Japanese big three (Nissan, Honda, Toyota) are very reliable cars. My friend has a Spec-V that he races all the time since 03, and he has never had any problems with it.
Old May 2, 2006 | 06:25 PM
speedracer209's Avatar
Default Re: $1500 left....what to buy? (jdmboi86)
lol SE-R ahahaha. I took one in my 93 ls with 3 people in my car and 2 in his we bother just had cold air intakes. They are jokes a shitty step up to the Si. But in regards to your question, if you got no smog in your area I would get one of those turbo kits on eBay they are like $750-$900 my friend has used many of those on his hatches and got into the mid 11's on B20 Vtec's. but if youre worried about cops. just do the bolt on magic and a good set of cams that should keep you happy for a while, plus all motor is more reliable. less to worry about
Old May 2, 2006 | 07:07 PM
Default Re: $1500 left....what to buy? (speedracer209)
I'm not saying Spec-Vs are the fastest cars ever made. I said they are quick for what they are. How bad did you beat the Sentra? I'm sure it wasn't by a whole lot. Which means with a motor swap, you barely beat him. So compared to a D16, the VQ25 is badass.
