HVAC Removal
Does anyone know how to remove the HVAC from the 97-01 ITR's? I have tried taking the radio out and reaching behind for some clips but it's unaccessable. Any help would be great.
IM Todd00, he'll help you out.
Won't you Todd?
Won't you Todd?
-Carefully pry out the hazard and rear defrost buttons, and unplug them.
-Remove the screws inside that you just revealed.
-Disconnect the temp. adjusting cable that runs to the air flap. It is a loop on a post and a metal clip, it can be reached fron the passenger side footwell. Be careful not to damage the cable.
-Pull back on the top of the unit, and disconnect the fan and air position harnesses.
It should pull right out, I think that's it but I don't have a car or helms in front of me.
HTH
HTH
ewing
Aug 19, 2014 10:00 PM
