What are the signs of a blown head gasket?
Old May 2, 2006 | 02:34 PM
4drITR's Avatar
Default What are the signs of a blown head gasket?
What are the signs of a blown head gasket in an integra? I think might mine might be gone.
Old May 2, 2006 | 02:37 PM
Lan's Avatar
Lan
Default Re: What are the signs of a blown head gasket? (TurboGS-Rsedan)
Leaks... compression test
Old May 2, 2006 | 02:38 PM
Integra Integra's Avatar
Mine blew on my 99 Integra LS ( Bubbling in the reserve tank), over heating, coolant loss. I had a slight misfire also which threw CEL. Sweet smelling WHITE exhaust...
Old May 2, 2006 | 02:57 PM
mac_24_seven's Avatar
Default Re: What are the signs of a blown head gasket? (Integra Integra)
Have a cumbustion test done. It the liquid turns yellow, it's either the head or headgasket (or both :S )
It doesnt have to blow white smoke or have a power loss. My GSR screams and it has a blown headgasket, though its slight.
A quick fix if you don't have the cash to down your car is to take the thermostat out. Your car wont' get as hott and wont build up pressure and blow the water out the resivour. It's what I've got done to mine and its gettin me by.
Old May 2, 2006 | 04:19 PM
MasterKwan's Avatar
Default Re: What are the signs of a blown head gasket? (mac_24_seven)
I was looking at a head the other day where someone chose to wait to replace the head gasket. The hot combustion gases wore a huge groove in the head surface basically trashing the head. I'm not sure I'd drive with a blown HG.
Old May 2, 2006 | 05:15 PM
Default Re: What are the signs of a blown head gasket? (MasterKwan)
I can get the head rebuilt for $200.00 if that happens..which I hope it doesnt.
Old May 4, 2006 | 12:42 AM
Young Deezy Son's Avatar
another quick way is if u unscrew ur oil fill cap it will look like chocolate milk..
Old May 4, 2006 | 08:05 AM
waterp7's Avatar
I think my head gasket is leaking around the edges where it is bolted to the block. It always looks moist but doesn't leak terribly.
Do you think it needs to be replaced anytime soon? I was planning on having it fixed when I get the timing belt replaced in about 10k miles. What do you guys think? My car is a 94 LS with 74k miles.
Old May 4, 2006 | 08:17 AM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Default Re: (waterp7)
Blown head gasket the engine will run like crap, you'll be blowing white smoke due to the coolant in the combustion chamber, and you'll have some nasty lookin oil, as stated milkshake.
Old May 4, 2006 | 08:58 AM
1337whp's Avatar
Default Re: (ForceFed_Motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed_Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">Blown head gasket the engine will run like crap, you'll be blowing white smoke due to the coolant in the combustion chamber, and you'll have some nasty lookin oil, as stated milkshake.</TD></TR></TABLE> look in your oil pan for coolant
Old May 5, 2006 | 06:51 AM
Default Re: (1337whp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1337whp &raquo;</TD></TR><TR><TD CLASS="quote"> look in your oil pan for coolant</TD></TR></TABLE>
To check crack your oil pan bolt and if water comes out your screwed... you'll be able to see how bad it is by how long it takes till you see oil.
Old May 6, 2006 | 08:11 AM
CoolJimWhy's Avatar
Take your dipstick out with your motor on....splash some of the oil onto the header. Sounds like a cold steak hitting the grill? *tssssssssss* that's coolant sizzling which equals uh oh. If it just smokes, than you might be alright since it's just oil being burned. Brownish...yeah milkshake coolant color since that's oil and coolant mixed.
Old May 6, 2006 | 11:57 AM
kpop's Avatar
white smoke
Old Jun 4, 2006 | 02:40 AM
racingfan's Avatar
Default Re: What are the signs of a blown head gasket? (kpop)
what about oil in Radiator tank??
Old Jun 4, 2006 | 06:34 AM
kusyurdaddy's Avatar
overheating and smoking out the tail pipes.
Old Jun 4, 2006 | 12:31 PM
racingfan's Avatar
Default Re: What are the signs of a blown head gasket? (yellowitr_06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowitr_06 &raquo;</TD></TR><TR><TD CLASS="quote">what about oil in Radiator tank??</TD></TR></TABLE>
benjamin
Jul 2, 2022 11:49 AM
lifesastruggle
Engine Management and Tuning
Feb 15, 2017 03:22 AM
new_climber
12
Jan 13, 2009 09:08 AM
touintegra1
Oct 6, 2008 02:18 PM
crxpowr91
Aug 21, 2003 01:42 PM
