Breathers? what for ?
Old May 2, 2006 | 12:37 PM
Type_R_Kills's Avatar
Default Breathers? what for ?
just wondering what those little filters called breathers do for your motor, are they only for turbo setups? i have a n/a setup non vtec , h/i/e,
should i put it on or will damage ensue
Old May 2, 2006 | 12:47 PM
Schrader's Avatar
Default Re: Breathers? what for ? (Type_R_Kills)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type_R_Kills &raquo;</TD></TR><TR><TD CLASS="quote">just wondering what those little filters called breathers do for your motor, are they only for turbo setups? i have a n/a setup non vtec , h/i/e,
should i put it on or will damage ensue</TD></TR></TABLE>
Doesn't make a differnece on a N/a Motor. Just on Turbo Engines, where there is more pressures present. It won't hurt your engine to put a filter on it, but it won't help it either.
Old May 2, 2006 | 01:15 PM
good stuff! but what about the hole on the air intake , what happens to that? recirculate?
Old May 2, 2006 | 03:46 PM
-InteGSR-'s Avatar
Default Re: (Type_R_Kills)
i plugged mine with a rubber cap. You can get them from autozone
Old May 2, 2006 | 04:03 PM
REEMB18C1's Avatar
Default Re: (InteGSRyder)
its apart of your crank case ventilation system alot of people just put a 10 dollae filter i ran a hose back to my intake
Old May 2, 2006 | 04:10 PM
DC2 Mang's Avatar
Default Re: (REEMB18C1)
the breather filler on your valve cover actually does much more harm than good, the line was engineered to send blow by back into the intake manifold.
by putting a breather on you are sending all of your blow by into the atmosphere and the breather syster is not functioning as intended
after market catch cans work well for filtering out oil in the blow by and keeping your intake manifold cleaner, as long as they are hooked up properly
if you want an effective sistem go with a catch can and ditch the little filter on the valve cover
pcguy760
Oct 16, 2008 07:02 PM
91integraLSVTEC
Jan 14, 2008 04:22 PM
dangerranger21
Jun 15, 2006 08:30 AM
ICeDoUt
24
Apr 6, 2006 09:48 AM
torr
May 30, 2004 01:51 PM
