Where is the firewall on my 1993 Accord?
Old May 2, 2006 | 11:38 AM
floyd_rockz's Avatar
Default Where is the firewall on my 1993 Accord?
Trying to run amp wire the right way this time, but i cant seem to find the firewall. Nothing is there. Should I drill a new one. Let me know what ya think. thanks
Old May 2, 2006 | 01:36 PM
v4lu3s's Avatar
RTFM
if you dont have a firewall how do you separate the engine bay and the passenger compartment?
Old May 2, 2006 | 01:40 PM
Eddiebx's Avatar
you have to look very carefully, it's easy to miss, but it right behind the engine. make sure you turn the lights on if your in the garage looking for it. or try looking for it on a sunny day. night time might be hard to spot. but i promise you that it is there, i am pretty sure every car came from the factory with a firewall.
Old May 2, 2006 | 03:57 PM
KillerElfboy's Avatar
Default Re: (Eddiebx)
look behind the glovebox, abouts that area, you will prob have to drill a new hole, i did
Old May 2, 2006 | 04:58 PM
Ross 2.0's Avatar
In a Junkyard near you.
Now for the response that will actually help you some:
Every car has a firewall. It seems like you just have a misunderstanding of what it is.
There are a few good threads about running a power wire through the firewall. I can't think where you can run it in your car but just look for a rubber body plug to poke a hole in and run it through.
You can't expect people to know everything about a car right away. You have to learn somehow. Give them a break
Old May 2, 2006 | 06:13 PM
HONCORD's Avatar
Default Re: Where is the firewall on my 1993 Accord? (floyd_rockz)
I figured u meant firewall gromet, right?
Old May 3, 2006 | 06:43 AM
flight50's Avatar
Default Re: Where is the firewall on my 1993 Accord? (HONCORD)
short and simple. the firewall is the wall at the back of your engine bay. the wall of the engine and the wall of the inside.
zsiya
Oct 4, 2011 04:03 AM
yesirthepoptart
Mar 19, 2010 04:52 AM
tyronne1126
Lighting
Aug 17, 2008 07:03 PM
TrikMeister408
Nov 27, 2002 06:27 PM
legion1011
Oct 16, 2002 08:06 PM
