NEED HELP WITH MY SPEEDOMETER...DOESNT WORK
Old May 2, 2006 | 11:28 AM
greddy13's Avatar
Default NEED HELP WITH MY SPEEDOMETER...DOESNT WORK
ok so in 2 days im goin to get my inspections and the only thing wrong is the speedometer...it doesnt work....and the calbe comes out when u pull it off the trans or w/e... what do i do to fix this?!?!?
Old May 2, 2006 | 11:42 AM
89efhatchcrap's Avatar
Default Re: NEED HELP WITH MY SPEEDOMETER...DOESNT WORK (greddy13)
buy a new speedo cable, and install it
Old May 2, 2006 | 12:41 PM
Khmi's Avatar
Default Re: NEED HELP WITH MY SPEEDOMETER...DOESNT WORK (89efhatchcrap)
you sure the speedo cable is pluged in on the tranny?
Old May 2, 2006 | 05:10 PM
greddy13's Avatar
Default Re: NEED HELP WITH MY SPEEDOMETER...DOESNT WORK (Khmi)
yea, i think, but the hole calbe comes out like you can take the HOLE cable out of the black hose line.
Old May 2, 2006 | 05:25 PM
SFlCrx's Avatar
take it out and look at the vss and if it is not attached go buy a new one and make a new hole in the firewall (so much easier then running it through the original hole) and put it on the vss and have a good day
Old May 2, 2006 | 05:28 PM
greddy13's Avatar
Default Re: (SFlCrx)
sounds easy? im gonna see if i can fix this one, and the day i go to get my inspections im gonna take a new one up there n get my friends dad to put it in so he'll pass it
Old May 3, 2006 | 05:58 PM
greddy13's Avatar
Default Re: (greddy13)
fixed it, wasnt pluged in at the cluster
Old May 3, 2006 | 06:41 PM
wood 1's Avatar
Wow, just goes to show how simple many fixes can be------ Just spend a little time and follow the problem from one end to the other and many times your problem will be solved! Nice work on finding your problem.
GPC91
Sep 17, 2012 01:11 PM
meseetree
Jun 2, 2006 07:19 AM
uriba69
11
Mar 11, 2004 12:07 PM
PhatHardy
Jan 6, 2003 08:01 AM
Brian_92GSR
Jun 24, 2002 08:14 PM
