can someone tell if theres any way to tell h22 apart
Old May 2, 2006 | 06:43 AM
FIST321's Avatar
Default can someone tell if theres any way to tell h22 cams apart
ok what i wanna know is i have h22a4 an i have a set of cam that i was told were type s cam i didnt even know if theres a difference in these cams can someone help me out all i wanna know is there any ways to find out what i have an is it even worth sawping the cams out or not
Old May 2, 2006 | 08:01 AM
FINEBB6's Avatar
Default Re: can someone tell if theres any way to tell h22 cams apart (FIST321)
there is a difference. the type-s cam is a jdm part and the lobes are more aggressive. If you have a stock engine then you don't have these, but if you do switch them you will notice a difference
Old May 2, 2006 | 08:46 AM
Eddiebx's Avatar
only way to tell is to measure the lobes and compare them to a stock cam
Old May 2, 2006 | 08:51 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">only way to tell is to measure the lobes and compare them to a stock cam</TD></TR></TABLE>
x2
Old May 3, 2006 | 12:06 AM
FIST321's Avatar
oh ok thanks for the help
kraquepype
Dec 24, 2018 08:14 AM
kraquepype
Engine Machining & Assembly
Dec 8, 2018 03:38 PM
trooper0641
Feb 23, 2008 07:32 AM
blkwidow420
Apr 14, 2005 01:37 AM
