b16a bolt torque?
Old May 2, 2006 | 05:22 AM
BluCivicDriver93's Avatar
Default b16a bolt torque?
sorry if this has already been posted but i've searched and hane had no luck... im looking for the torque specs for a b16a i need intake mani, exhaust mani, crank pulley, pressure plate to flywheel, and cam cap specs. i found the specs for the d16... which ones are different? if you can help me out it would be much appreciated. thanks, ben
Old May 2, 2006 | 05:53 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: b16a bolt torque? (BluCivicDriver93)
Haynes manual
Old May 2, 2006 | 07:08 AM
Luserkid's Avatar
Default Re: b16a bolt torque? (black_EM1)
Hondas are majoritly the same specs.
Intake manifold - Hand tight (i think 16lbs if you need a number)
Exhaust - Hand tight (16lbs if you need a number)
Pressure plate - 18lbs
Cam Caps - 7lbs.
Crank pully - 135lbs
Old May 2, 2006 | 07:09 AM
ya i was hoping not to have to buy one... im putting a b16 together for a buddy and im never goingto need the manual again... but thanks
Old May 2, 2006 | 08:02 AM
black_EM1's Avatar
Community Builder
Well, tell him to buy the damn book, then
Old May 2, 2006 | 09:08 AM
spoonek9's Avatar
Default Re: b16a bolt torque? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Hondas are majoritly the same specs.
Cam Caps - 7lbs.
Crank pully - 135lbs</TD></TR></TABLE>
Just about every number you listed is incorrect.
Old May 2, 2006 | 01:20 PM
Default Re: b16a bolt torque? (spoonek9)
haha want to tell me the correct ones?
Old May 2, 2006 | 06:30 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonek9 &raquo;</TD></TR><TR><TD CLASS="quote">
Just about every number you listed is incorrect. </TD></TR></TABLE>
Oh yea thats helpful.
Ones that i was wrong on were: Exhaust nuts/bolts (come on who really uses a torque wrench on them anyway). Everything else were +/- 1. Heres pics straight from the helms.
Edit: **** photobucket shrunken the pics.
Old May 4, 2006 | 02:30 PM
thanks man this helps a lot
yee510
Nov 28, 2011 01:20 AM
Team_Boost2
Jan 13, 2009 02:35 PM
Dasfinc
Feb 28, 2008 10:03 AM
Master23
Jun 19, 2005 05:11 PM
NyspeeD
Feb 25, 2004 07:13 AM
