B16A in to 92 civic HB
will a B16A fit in to a 1992 civic HB if so what parts do i need also will it fit using the stock motor mounts??
i still have the car the B16A is coming out of 1991 honda integra xsi.
You will need a special mount kit along with a wiring conversion since the 91 is an OBD0 set up with cable.
You make 3 different post, asking the same question, but only 1 you provide the correct information. Next time, just take your time when you post, post once, and give all needed information.
See your other post below for full details...
https://honda-tech.com/zeromodi...06697
Modified by jdmcars.com at 11:33 PM 5/8/2006
DailyBlown
Nov 21, 2002 10:22 AM
