i know you hondata guys can answer this....
well i was wondering if you can run hondata s200 w/ boost option with a motor that is using itb's allmotor?
also can this hondata boost option be disabled?
my setup is as follows:
LS/VTEC
ctr pistons
cometic thick head gasket
arp rod/ main, head bolts
gsr h2o pump
gsr pan
gsr girdle
itr cams
jg cam gears
954 cc itb's
440 cc blue tops
MSD Sport ignition
denso plugs
ngk plug wires
aem fpr
walbro 255 lph fuel pump
dc 4-1 header
CTR n1 crank pulley
my crx is setup for obd 1 and im using an obd 1 ecu.
LS/VTEC
ctr pistons
gsr h2o pump
gsr pan
gsr girdle
itr cams
jg cam gears
954 cc itb's
440 cc blue tops
MSD Sport ignition
denso plugs
ngk plug wires
aem fpr
dc 4-1 header
CTR n1 crank pulley
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2 »</TD></TR><TR><TD CLASS="quote">I dont think so, but bump for a better answer. </TD></TR></TABLE>
That sounds about right... if you go to hondata's website it explains it more but they state that its a "Boost capability" which seems to me as an option you dont have to use.
lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIP Indian Larry »</TD></TR><TR><TD CLASS="quote">i dont know either but you should get better results in Tech/Misc section.</TD></TR></TABLE>
already tried not too many people have inputs there
any help is greatly appreciated.
lol
Well, heres what i have come up with... its a boost option which in the dictionary means something, option in my opinion means you dont have to use it, just like other features on hondata you dont have to use.
Im pretty sure you could use the s200 without having to use the boost option. If your deciding to use hondata anyway im sure testing it out wont hurt. Maybe even have the boost option capabilities removed from the chip.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed_Motorsports »</TD></TR><TR><TD CLASS="quote">Well, heres what i have come up with... its a boost option which in the dictionary means something, option in my opinion means you dont have to use it, just like other features on hondata you dont have to use.
Im pretty sure you could use the s200 without having to use the boost option. If your deciding to use hondata anyway im sure testing it out wont hurt. Maybe even have the boost option capabilities removed from the chip.</TD></TR></TABLE>
man knows his stuff
Edit. went to hondata.com the boost capability is 200 more and isnt required unless you are running a turbo or sc
http://www.hondata.com/featuresboost.html
man knows his stuffEdit. went to hondata.com the boost capability is 200 more and isnt required unless you are running a turbo or sc
soslodelsol
May 2, 2006 10:37 PM
