quick C Pillar Bar install question, thank u for help
Old May 1, 2006 | 10:04 PM
da9pwnsu's Avatar
Default quick C Pillar Bar install question, thank u for help
Which way should it go? rofl, noob question
http://i1.tinypic.com/x1f49y.jpg
Old May 1, 2006 | 10:20 PM
.one lane's Avatar
.likes trains
when i had mine i removed my rear seat belts. i guess it wouldnt really matter which way you do it.
Old May 1, 2006 | 10:34 PM
importdude2000's Avatar
i dont understand the picure at aLL
but u have to remove rear seatbelts to put the bracket on..
then bolt the seatbelts back on
it then sits/works like stock
this is on a DA
edit the ring where the bolt goes threw the seatbelt plastic hole thiny goes right behind the black bracket and wedged in between the pillar
so figure one
Old May 1, 2006 | 10:54 PM
da9pwnsu's Avatar
Default Re: (importdude2000)
ok so this is what it looks like right now:
its figure 2 installation on the first pic
Old May 1, 2006 | 11:04 PM
no2unenolife's Avatar
figure 2
Old May 2, 2006 | 12:34 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (no2unenolife)
I didn't know that bar would work with the seat belts hooked up too. Nice to know
Old May 2, 2006 | 06:19 AM
RaceMyGhost's Avatar
Default Re: (SlammedDC2)
ya i have that bar in my 2 door and it sits up just like the image posted up. its a direct bolt on and allows u too keep your seat belts.....only problem is no one can really sit there lol especially if you have one stiff *** ride
Old May 2, 2006 | 07:01 AM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Default Re: quick C Pillar Bar install question, thank u for help (oldschoolDA9)
The bar goes over the seat belt brackets... if you choose to use them. The manufacturers state that they are compatible but i ended up having to put in spacers behind the bar to meet the seat belts evenly.
Old May 2, 2006 | 10:20 AM
da9pwnsu's Avatar
yeah u just have to go to liek home depot and buy some longer screws with the "8 fine" thread...size 7/16, then everything will bolt on fine
purplerain11
Suspension & Brakes
Jul 30, 2011 10:38 AM
EF9_RIDER37
Jan 5, 2010 11:31 PM
93grayeg
Jun 12, 2009 09:37 PM
DC4GB
Oct 3, 2006 07:02 PM
BLKMamba
Jun 12, 2002 01:48 PM
