I need a Silicone nipple or pipe hole cover , dont know whats its called.
ANyone know where i can get silicone nipples, like the ones u get on aftermarket intake pipes . I wanna block off the port on the valve cover and the coolant line for the iacv and i dont know where to find these, or what they may be technically called ?
Thanks
Thanks
You could just make your own if you like.
Just get a bit of coolant line and plug the end with a screw.
Best to use a screw that is a bit bigger than the hose. Also put some silicone over the threads of the screw...then screw the screw into the end of the hose.
Yeah that would work fine for the coolant , but for the valve cover i want something that looks a little nicer, i know those nipples exist , just need to find one.
they sell them in a varity pack of different sizes try your local parts store there just a nipple cap
Blacknight117
10
Dec 31, 2012 04:57 PM
Charlie Moua
Welding / Fabrication
16
Nov 12, 2010 01:38 PM
racinskittle
Sep 26, 2003 02:35 AM
