lsvtec coolent and oil mixing please help asap
Old May 1, 2006 | 06:06 PM
AcuraIntegraLS-T's Avatar
Default lsvtec coolent and oil mixing please help asap
Got my stupid car running about 3 hrs ago, my crome crap wasnt working, so i barrowed my friends hondata s300 system. I got the fuel running a little rich but ideling and 14.7 drove it about 1 mile and it started overheating. So i turned the heater on and it was ice cold, i got it home and there was milky oily crap all over the hood and motor. I dont have anything going to the fitting coming off the vave cover, and i dont have anything going to the oil catch that is on the back of the motor. I cant find where it is coming from thouse are the only places that i can fill hot air coming from. All the coolent lines are hooked up. The only thing i can think is that the head gasket was messed up. I used a gasket for the vtec head. I used golden eagle head studs and torqued them down to spec. The bottom end was just rebuilt and this is the first 2 miles on the motor. I dont know what is wrong i hope that someone can help please and thanks. B18b block with golden eagle sleeves, 84mm, b16 head
Old May 1, 2006 | 08:05 PM
i need help please!!!!!!!!
Old May 2, 2006 | 09:04 AM
still need help! I pulled the head and there was water/oil//milk under the head gasket on teh motor side. So i'm guessing that it wasnt sealed but i dont know why> i guess i will go see if the head is warped. Any help or ideas would be great thanks
Old May 8, 2006 | 02:18 PM
turboed-single-cam's Avatar
Default Re: (AcuraIntegraLS-T)
Headgasket???
Old Jun 4, 2006 | 06:46 PM
holotta_eg's Avatar
Default Re: (turboed-single-cam)
you are supposed to plug the head where the old oil plug was . ls dosent have that hole in the block so you have to p;ug it so the head wont push out oil
djb97ek
Apr 11, 2010 09:00 PM
scspeed
Mar 28, 2010 06:50 AM
scspeed
Apr 18, 2009 01:54 PM
YumYumTurbo
Jun 10, 2007 10:47 AM
Mattb16teg
Jan 27, 2005 09:07 PM
