viper 791x remote and trunk release
Old May 1, 2006 | 04:48 PM
ezekel's Avatar
Default viper 791x remote and trunk release
ok a few more questions came about. i currently have the 791x alarm system that has this remote
reading DEI site they said the alternative remote is
reading around i read that someone was able to use the 571xv remote
so the question is: am i able to use another remote like the 571xv? the 2 way is nice, but not to afraid of watching the lcd all the time and i hate the alternative remote
2. im going to get the dei trunk release and install it on my 99 si. would any additional parts be needed that i need to order, or would i be able to go to radio shack and get them? or would i need any additional parts at all?
Old May 2, 2006 | 03:59 AM
JSPECSIR's Avatar
you also have to change the antenna if your going to use the led remote. whatever dealer you get the remote from can get you the antenna also. they are in the dei catalog,one for lcd and one for led. anyway as far as the trunk goes I used a dei door lock actuater on my 94 hatch, my wifes 95 coupe, and a customers del sol at work. but even if you use the soleniod you should be ok, but you will need a relay.
Old May 2, 2006 | 08:57 AM
fcm's Avatar
fcm
Old Fart
Default Re: viper 791x remote and trunk release (ezekel)
You can check DEIs remote cross reference guide at... http://www.dei.com/
And unless you have power trunk release now, [don't think so] you will need the solenoid and a relay. 94
Old May 3, 2006 | 11:43 AM
jdmotorsports's Avatar
Default Re: (5THGENSI)
its the same antenna, they just look different. the lcd and led are they same thing, just different displays. i've already programmed a responder alarm with led remotes. worked fine.
and its http://www.directed.com
and you'll just need the solonoid and a relay. thats it.
Old May 4, 2006 | 03:44 AM
JSPECSIR's Avatar
Default Re: (jdmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">its the same antenna, they just look different. the lcd and led are they same thing, just different displays. i've already programmed a responder alarm with led remotes. worked fine.
and you'll just need the solonoid and a relay. thats it. </TD></TR></TABLE>
huh, thats odd . we had several customers wanting led remotes for extras and we couldnt get them to program, and our rep said the ant. were different and showed us the two different part #s in the book. iokno i havent tried it in about a year maybe ill try it again.
Old May 4, 2006 | 08:37 AM
they are different antennas, but they ride the same freqs. the vx uses the wire lead antenna to get a big more distance. the leds use a compact antenna unit. the vx should be able to use the led remotes, but the led systems didnt match up with the lcd remotes.
Old Dec 9, 2006 | 12:38 AM
dafuzzbudd's Avatar
*digging up old thread*
$60?..
will this work for the trunk ?
http://cgi.ebay.com/ebaymotors...QrdZ1
what else might be needed?
Old Dec 9, 2006 | 08:33 AM
suspendedHatch's Avatar
Default Re: (dafuzzbudd)
That's overkill. It's bulky and hard to hide. Just get a door lock actuator and a relay like everyone said.
Old Dec 9, 2006 | 12:21 PM
fcm's Avatar
fcm
Old Fart
Default Re: (suspendedHatch)
Trunk release is not what a door lock actuator is for, a door lock actuator does not have as much power as a solenoid, a door lock actuator needs polarity reversing to work properly, it is not the right piece to use for trunk release.
It's a whole diff. story if it's trunk lock/unlock, [on cars that have it] you want. 94
Old Dec 9, 2006 | 10:08 PM
dafuzzbudd's Avatar
Default Re: (fcm)
i only want it to unlatch itself so ill have to actually open it myself
$60 is not worth it
Old Dec 10, 2006 | 07:23 AM
fcm's Avatar
fcm
Old Fart
$60???
If your car has a locking trunk with handle, [like a car door] you can use a door lock actuator, [wired to the alarms door lock outputs] and a basic one should not cost more then $10 US... http://cgi.ebay.com/ebaymotors...ZWD1V 94
Old Dec 10, 2006 | 07:19 PM
dafuzzbudd's Avatar
Default Re: (fcm)
well i got a 94 civc
this thing would be installed on the inside of the trunk door on the cable?
Old Dec 10, 2006 | 07:52 PM
JSPECSIR's Avatar
ive got a door lock actuator in my 95 ex on the rod that comes from the trunk key cylinder. it is setup to either push or pull(i cant remember) when 12 volts is applied to the correct wire. the other wire gets grounded.
Old Dec 10, 2006 | 08:13 PM
perseverance's Avatar
i used that solenoid.. it's bulky but i managed to make it look clean in my ek. only thing is i had to drill two holes to put the plate on and after a while it started getting loose and would work intermittenly. so i'm gonna get the plate welded on there in a few days for added stability.
Old Dec 11, 2006 | 12:01 PM
dafuzzbudd's Avatar
Default Re: (perseverance)
alright, i think i have the confidence to isntall this when i get my alarm around xmas time.
thanks for the good info
Old Dec 12, 2006 | 04:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote">i used that solenoid.. it's bulky but i managed to make it look clean in my ek. only thing is i had to drill two holes to put the plate on and after a while it started getting loose and would work intermittenly. so i'm gonna get the plate welded on there in a few days for added stability.</TD></TR></TABLE>
*cough
Exactly. Just get a door lock solenoid. I'm glad you agree with us.
dragonjay006
Audio / Security / Video
May 12, 2009 08:57 PM
stephen_civic98
Mar 15, 2007 06:50 PM
GoLowDrew
May 30, 2006 03:37 PM
