Wheel sizing question
Old May 1, 2006 | 04:14 PM
05member y0's Avatar
Default Wheel sizing question
What is the lowest offset anyones run on there lude, specifically 4th gen.
I ask because I am looking at a set of wheels for autox that are 15x8 with a 0 offset.
do you think they would work?>
thanks
Old May 1, 2006 | 04:17 PM
soundbomber's Avatar
Default Re: Wheel sizing question (05member y0)
no, not without flaring out the fenders
Old May 1, 2006 | 04:23 PM
Default Re: Wheel sizing question (soundbomber)
do you thikn that clearance wise as far as the brakes are concerned that they would fit. im not going to be daily driving these, so if they stick out a bit i dont mind, plus my ride height isnt too low so rubbing would be minimal
Old May 1, 2006 | 04:25 PM
i highly doubt it. what wheels are they anyways? panasports? watanabes? trying to throw ae86 wheels on a lude?
Old May 1, 2006 | 04:29 PM
there sportmax 002's there pretty damn sweet for 120 a wheel.
Default Re: (05member y0)
meant for like miatas and such but ive seen em on scion xb's
Old May 1, 2006 | 04:33 PM
ic, why not just save yourself the hassle and get some slips? i mean, i know it's cliche and played out, but if it's a track car, who cares right?
but, i think u may be able to pull it off if you do some calculating, if the offset is 0, you've got 4" either way of just straight up rim. i'm not saying it can't be done without spacers, but as a bolt on affair, i don't really see it happening, but an 8" wide wheel does so dope
Old May 2, 2006 | 08:56 AM
found somebody who put em on an ff honda.
Old May 2, 2006 | 03:42 PM
helicopter201's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 05member y0 &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
off topic, that bodykit = pure rice even if it was ment for "aerodynamics" (snickers) or "weight saving" they coulve done alot better oh well, its an ep3 so its not that much of a loss
Old May 2, 2006 | 03:55 PM
thanks for the helpful input
Old May 2, 2006 | 04:20 PM
" I sense sarcasm" " Really"? " Oh no you did it again"!
Old May 2, 2006 | 04:21 PM
Silver Surfer's Avatar
Default Re: (soundbomber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">ic, why not just save yourself the hassle and get some slips? i mean, i know it's cliche and played out, but if it's a track car, who cares right?
but, i think u may be able to pull it off if you do some calculating, if the offset is 0, you've got 4" either way of just straight up rim. i'm not saying it can't be done without spacers, but as a bolt on affair, i don't really see it happening, but an 8" wide wheel does so dope</TD></TR></TABLE>
why would you need spacers for a "0" offset?
you would need spacers for something like a +50 offset
as long as he is not too low it should work fine.....they just need to be able to clear the fender.....but for daily driving i wouldn't be good, probably be hastled by the cops for having your wheels stick out beyond the fenders
Old May 2, 2006 | 04:43 PM
SnlpeR's Avatar
of course they will work
right height must be high
and you should be on really stiff springs
Z99doc
Oct 11, 2015 03:50 PM
ITRBOY1433
Apr 17, 2011 12:00 PM
oj5joker
May 8, 2010 09:33 AM
es_squared
Oct 9, 2008 02:45 AM
copeman
Apr 9, 2007 05:22 AM
