Oil pan installation, gasket or silicone?
I picked up a new OEM oil pan gasket from honda, as I'm installing it, I check the book to make sure I don't put silicone anywhere and then it reads to apply a 1/8th inch bead of silicone around the pan. From what I can understand, this is disreguarding the fact that it came with an oil pan gasket. I know DSMs, you don't want to use gaskets (They come with silicone from the factory) but when I dropped my oil pan, obviously the stock honda gasket came with it.
So which is better, to use the gasket I got from honda or just use silicone?
you put honda bond on the corners where the seal covers meet the block. just a dab. make sure you dont over torque the nuts/bolts, and make sure you go in the right order
i asked a mechanic at my stealership and he said dont use and honda bond. put it on dry and follow the tightening sequence. the honda bond will make it leak.
i have never had a problem with honda bond. that is the reason the helms manual says to use it. i understand he is a mechanic and he does this alot. but i have used this method many times and ite been flawless. i actually first heard about this method from a honda technician. i guess some guys do it differently but i would use honda-bond
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18B-SC »</TD></TR><TR><TD CLASS="quote"> i have never had a problem with honda bond. that is the reason the helms manual says to use it. i understand he is a mechanic and he does this alot. but i have used this method many times and ite been flawless. i actually first heard about this method from a honda technician. i guess some guys do it differently but i would use honda-bond</TD></TR></TABLE>
I think it is a preference more than anything. I used hondabond on both sides of mine and it doesn't leak.
I know for a fact that the factory service manual doesn't mention anything about hondabond, so I guess it depends on what manual you are using because it seems to have a discrepancy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Schmoo »</TD></TR><TR><TD CLASS="quote">
I know for a fact that the factory service manual doesn't mention anything about hondabond, so I guess it depends on what manual you are using because it seems to have a discrepancy.</TD></TR></TABLE>
well this is a picture directly from helms manual, my version says to put it on the corners. you can kinda read it in the picture
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by helms manual »</TD></TR><TR><TD CLASS="quote">apply liquid gasket to these 4 points</TD></TR></TABLE>
Yep, I did exactly as the manual states for applying Hondabond where the main seal and the oil pump meet up with the oil pan flange. I did the same thing for the myHondaHabit.com oil pan gasket that I installed as they recommend installing their specialty gasket in the same manner as the nitrile OEM version. It worked out well and resolved my leaks.
dth0ng69
Jul 18, 2009 12:04 PM
