resistor spark plugs colder than heat range 7? iridium plugs?
with my engine managment i can't run a non-resistor spark plug. since ngk only has a resistor plug in the 7's (BKR7E).....does any other brand make a colder resistor plug or should i just run the iridiums?
any help, suggestions, info is appreciated!
It's weird, with motec you can run any coil, any trigger system, any sensor, etc. You're not stuck with 1 option for everything like some systems...
ngk has the cheapo bkr's up to an 8, they also have the iridums up to a 9. stay away from the denso iridum, they are garbage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">with my engine managment i can't run a non-resistor spark plug. </TD></TR></TABLE>
That sucks...
Need new management...
That sucks...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">It's weird, with motec you can run any coil, any trigger system, any sensor, etc. You're not stuck with 1 option for everything like some systems...
yeah i know the feeling... Flexiablitity is very important in ecu's.
</TD></TR></TABLE>yeah i know the feeling... Flexiablitity is very important in ecu's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">ngk has the cheapo bkr's up to an 8, they also have the iridums up to a 9. stay away from the denso iridum, they are garbage</TD></TR></TABLE>
Waht's wrong whit Denso Iridum plugs?
Anders.
Anders.
We ran denso plugs in just about everything we had. The full blown drag car making over 1600hp and all of our Pro FWD cars making over 800hp never had a problem. As tony said there is a easy cure for detonation.
Now for a non-resistor plug you can run the R5671A-(7-11) which Tyler H has been running in his car with no problem.
For a resistor plug R7235-(8-9) or a BPR(8-9)ES.
I have never ran the FIRST resistor plug so I am not sure how good they will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">Well there's any easy cure for that.
haha, yeah, but most people are idiots..
i had one kid... 430hp on pump gas, built block.. put 87 octane in by mistake nad called me 2 days later saying its been making a funny noise for a couple of days and now it dosnt run right
haha... anyway, denso's cost too damn much
anyone ever used Brisk spark plugs??? http://www.briskusa.com
</TD></TR></TABLE>haha, yeah, but most people are idiots..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">since ngk only has a resistor plug in the 7's (BKR7E)</TD></TR></TABLE>
I've seen BKR8E's and BKR9E's before.
The equivalents in Iridium's just have IX after them. Around here the IX's run like $7 or $8 each which isn't hateful considering platinum and race plugs run anywhere from $20-$30 a piece.
what EMS is it? hope you didn't just put it in. new EMS in the middle of the season is not a good ideal
Chris Green
Chris Green
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">You should get a motec
haha chris and I tell him that all the time.
</TD></TR></TABLE>haha chris and I tell him that all the time.
thanks i appreciate it...this post was actually just recently brought back from the dead. i have made the changes to be able to run copper plugs now and have all kinds to choose from!
yea tony i heard that cam trigger kits pretty badass!
as far as im concerned.......if you have AEM its not a "want" thing...its something you NEED!
