Need helpf fabbing a eg hath roll cage
I have a friend in the metal fabrication industry, i have some knowledge and experience in metal fabrication but i just wondered if anyone could help me here.
How can i/what is the best way to mock up a cage and then get it made? as in how would i make a acurate template for my friend to follow?
And does the cage have to be assembled inside the car or can they be lifted in and welded down?
any help much appreciated thnx
Thats the problem there isnt anywhere, i live in the UK, the only places to get cages from over here are bolt in's
Probably just have to look harder. Try asking around at local races.
One word of advise, I'd rather have no cage at all than a poorly built cage.
ok, i just had a good look and found a couple, i just wondered tho because it would be way cheaper if there was a way my friend could fab it and then i could get it welded in, just a thought.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ezza »</TD></TR><TR><TD CLASS="quote">ok, i just had a good look and found a couple, i just wondered tho because it would be way cheaper if there was a way my friend could fab it and then i could get it welded in, just a thought.
thanks
http://www.safetydevices.com/
These guys make nice pre-bent tube sets that you just have to fit and weld in.
thanks
</TD></TR></TABLE>http://www.safetydevices.com/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3a_eg_hatch »</TD></TR><TR><TD CLASS="quote">use cardboard for all the bends and just draw it out. that will give u an idea then u just have to f*ck with it to make it work.
thats what i thought
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 »</TD></TR><TR><TD CLASS="quote">
These guys make nice pre-bent tube sets that you just have to fit and weld in.</TD></TR></TABLE>
Thnx, but i can get the metal work done, its just the design/sizes/bends ect i need to find out
