Do 88-89 healights mount the same as 90-91?
Old May 1, 2006 | 09:53 AM
pinecone's Avatar
Default Do 88-89 healights mount the same as 90-91?
I was just wondering. Do 88-89 headlights mount the same as 90-91? Could you put 89-89 headlights as a replacement to 90-91 headlights? I know the corners are different. Would that require a different header panel because the old style screws in and is not bolted?
Old May 1, 2006 | 10:32 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Do 88-89 healights mount the same as 90-91? (pinecone)
The difference is the frame bracket of the headlight (#3 & #31). If you just replace the bulb lense housing (#2 & #30) you won't have to worry about corner lights at all. You probably don't want 88-89 corner lights anyways since they have those stupid screws on the side (I hate mine)...
Old May 1, 2006 | 10:51 AM
CRX_DOHC_ZC's Avatar
agreed ^^ the only difference is, is the brackets i had to change mine its not that bad.
HmgLauj69
23
May 14, 2005 06:53 AM
B.S._TURBO
Nov 15, 2004 02:50 PM
CrX-To-Tha-Max
10
Mar 6, 2004 06:04 PM
24hourflipness
Apr 16, 2003 01:43 PM
tunedcivic
Mar 22, 2002 01:38 PM
