oil on spark plugs
Old May 1, 2006 | 08:34 AM
bOOsted_D16's Avatar
Default oil on spark plugs
ok heres the deal...on my 92 accord f22....i went to go check my compression the other day and when i took my plug wires off the plug ther is oil on the plugs....its pretty heavy 2...whats wrong?? it wasnt like that when i put my ngk's in and took the stock 1s out bout 4 months ago
Old May 1, 2006 | 08:37 AM
d112crzy's Avatar
it means your spark plug tube seals are blown.
you have to replace them.
http://www.cb7tuner.com/vbb
search that site for spark plug tube seals
or search here.
Old May 1, 2006 | 08:39 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: oil on spark plugs (tjay92accord)
It's either the upper or lower spark plug tube seals. Generally it's the upper spark plug tube seals. To replace those you just remove the valve cover, pop the old ones out and pop the new one in and put the valve cover back on. The lowers are more involved, someone did a write-up on it, I'll see if I can find it.
here you go...
http://www.cb7tuner.com/vbb/sh...seals
http://www.ozaccord.com/forums/showthread.php?t=28
Old May 1, 2006 | 08:46 AM
Default Re: oil on spark plugs (TouringAccord)
thanks guys...i jus hope its that dam top seal...cuz i jus put my whole head back together and would hate to have to take it all apart again lol
Old May 1, 2006 | 08:48 AM
d112crzy's Avatar
if there was ALOT of oil, its prolly the lower ones as well.
Old May 1, 2006 | 08:51 AM
Default Re: (d112crzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d112crzy &raquo;</TD></TR><TR><TD CLASS="quote">if there was ALOT of oil, its prolly the lower ones as well.</TD></TR></TABLE>
well its not drenched but the plug is pretty oil...i can go take a pic really fast
Old May 1, 2006 | 09:44 AM
Default Re: (tjay92accord)
[IMG][/IMG]file://C:\Documents%20and%20Settings\Owner\My%20Documents \My%20Pictures\tjay\tjay%20011.jpg
Old May 1, 2006 | 09:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tjay92accord &raquo;</TD></TR><TR><TD CLASS="quote">[IMG][/IMG]file://C:\Documents%20and%20Settings\Owner\My%20Documents \My%20Pictures\tjay\tjay%20011.jpg</TD></TR></TABLE>
^ im pretty much a retard and dont know how 2 put a pick on this forum
Old May 1, 2006 | 09:52 AM
H-T Order of Merit
first you have to upload the picture to an online hosting site like ImageStation or PhotoBucket for example.
Once you have the picture uploaded onto the hosting site, right click the uploaded picture and go to properties.
Then highlight the URL and right click the highlighted area and click Copy.
Then come on here and click the image tab like you did. Then right click inbetween the ][ on the image tag and click Paste.
That will post your picture on the site. I hope that made sence.
Old May 1, 2006 | 09:58 AM
Default Re: (TouringAccord)
Old May 1, 2006 | 12:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tjay92accord &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
does this look like a bottom or top seal??
Old May 1, 2006 | 01:45 PM
92ehatch's Avatar
both the bottom and top seals are obove the spark plug.
there is no oil on the threads of the spark plug.
you need to go to advance and get a valve cover gasket kit.
comes with, valve cover gasket, upper spark plug tube seals, lower spark plug tube seals (which are about halfway down the tube)
there is no way we can figure out which seals are bad from that picture, most likely the bottom,
Old May 1, 2006 | 02:40 PM
H-T Order of Merit
It's hard to tell just from pictures.
If it was me, I would buy the valve cover gasket set and start with that. If that doesn't work, then go ahead and tear it apart and replace the lower ones. But I would personally start with the cheapest and easiest ones. It seems like most people end up finding the upper seals to be the problem.
Old May 1, 2006 | 04:44 PM
92ehatch's Avatar
could always, clean the tubes out, run the car for a bit, then take a look.
you will be able to see it coming out of either the top or bottom seals.
i could tell on mine.
Damon Reeves
May 15, 2006 10:29 AM
BB6racer
Jan 18, 2006 05:20 PM
illusion
Apr 30, 2003 06:47 PM
gixxer6
Oct 29, 2002 01:10 PM
si91
May 28, 2002 07:33 AM
