2001 EX V6 timing belt and water pump
Old May 1, 2006 | 08:30 AM
rasta420's Avatar
Default 2001 EX V6 timing belt and water pump
hey my friend has a 01 ex V6, and he wants to change out his timing belt and water pump. besides those two, and the belt tensioner, what are other parts/seals/gaskets that can be accessed and changed while doing this?
i was looking at the diagram for the timing belt on hondaautomotiveparts and i see a timing belt adjuster and automatic adjuster. do these have to be changed along with the tensioner? or are they different names for the tensioner or something...
thanks
Old May 1, 2006 | 10:12 AM
Ross 2.0's Avatar
In a Junkyard near you.
unless any seals are found to be leaking nothing else needs to be done.
Old May 1, 2006 | 12:58 PM
rasta420's Avatar
Default Re: (MooGoCow3)
well of course but id rather do preventative maintenance than replace seals when they start leaking. can anyone help me out?
Old May 1, 2006 | 06:07 PM
Ross 2.0's Avatar
Well if you want to go that route you can replace both cam seals, crank seal, valve cover gaskets and reseal the oil pan. Your going to be in the area and if your doing preventative then go for it.
sobey
Nov 9, 2008 09:55 AM
hkboy87
Jan 5, 2006 07:01 PM
ninerpilot
Aug 16, 2005 07:44 AM
98LS4dr
Feb 1, 2005 11:36 AM
JaiDieM
Sep 11, 2003 06:55 PM
