tranny wont engage at high speeds / revs........................
at low speeds / revs the tranny is as smooth as a babys butt but give it some stick through the gears then it wont engage until the revs drop. I have changed the oil which has made no difference. Any suggestions ? Also if you drop from 4th to 3rd you have to blip the throttle to pick up the revs for it to engage..............just like changing without using the clutch!!!!!!
Any links, suggestions or tips would be appreciated.
Synchro's or change the oil in it to synthetic.... It's time to start thinking about a new tranny......
MAYBE a misaligned clutch issue keeping the input shaft spinning, but I doubt it.
