'93 Accord: Heating-A/C dial broken
Old Apr 30, 2006 | 11:15 PM
Sohail's Avatar
Default '93 Accord: Heating-A/C dial broken
My dial for the temp. broke and pops out when I drive over a rough surface and the fan speed one is relatively easy to pull off its socket.
I called the nearest junk part place and was told I can't buy the dial individually from them rather I have to purchase the entire piece and that's the norm no matter where I look. This sounds kind of whack because it makes no sense to buy the entire heat set with buttons and dials and so forth and then install it -- does anyone know if this is bs and I can indeed grab just the dials from some place? Thanks..
Old Apr 30, 2006 | 11:44 PM
pos_cd5's Avatar
Default Re: '93 Accord: Heating-A/C dial broken (Sohail)
go to those walk in-u pull-it junkyards and take one out and put it in ur pcket and leave. or you buy one from http://www.tasauto.com for like 7 bucks
Old May 1, 2006 | 12:31 AM
YeuEmMaiMai's Avatar
Default Re: '93 Accord: Heating-A/C dial broken (pos_cd5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pos_cd5 &raquo;</TD></TR><TR><TD CLASS="quote">go to those walk in-u pull-it junkyards and take one out and put it in ur pcket and leave. or you buy one from http://www.tasauto.com for like 7 bucks</TD></TR></TABLE>
advocation of theft makes you a moron:
OP, you can buy new ones that are updated for like $8 a peice at the local honda dealer.
Old May 1, 2006 | 02:41 AM
OuttaGas's Avatar
ya they are no more than $8 at the dealer
Old May 1, 2006 | 04:43 AM
Ross 2.0's Avatar
In a Junkyard near you.
Just get a new one from your dealer or http://www.hondaautomotiveparts.com
if you get a used one you risk it breaking again
Old May 1, 2006 | 08:22 AM
accord-pro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pos_cd5 &raquo;</TD></TR><TR><TD CLASS="quote">go to those walk in-u pull-it junkyards and take one out and put it in ur pcket and leave. </TD></TR></TABLE>
WOW such a great advice,,,,,,,,,How would you like if someone visited your house and put something in their pocket and walked off with it..
DO NOT do to others what you do not want done unto you..
Yo sohail when you mean dial do you mean the **** ?? if so ,they are 5-6 dollars at the dealer
Old May 1, 2006 | 12:16 PM
Sohail's Avatar
Default Re: '93 Accord: Heating-A/C dial broken (accord-pro)
Yeah pro, it's the **** but not the push button, it's a dial..thanks for allt he replies guys.
Old May 1, 2006 | 12:19 PM
Sohail's Avatar
Default Re: (MooGoCow3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 &raquo;</TD></TR><TR><TD CLASS="quote">Just get a new one from your dealer or http://www.hondaautomotiveparts.com
if you get a used one you risk it breaking again</TD></TR></TABLE>
That worked out perfectly, that's actually an excellent source..really extensive inventory. Thanks again.
Old May 1, 2006 | 06:08 PM
Ross 2.0's Avatar
No problem at all. Just trying to help out.
Be sure you pull off the old metal ring before you try to put the new **** on (unless it remained in the broken ****)
Old May 1, 2006 | 09:07 PM
KillerElfboy's Avatar
Just make sure it is in fact just the **** thats broken, if its the cable behind the **** you have a bit more expensive problem
Old May 2, 2006 | 12:26 PM
dmurphy2k3's Avatar
Default Re: (KillerElfboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillerElfboy &raquo;</TD></TR><TR><TD CLASS="quote">Just make sure it is in fact just the **** thats broken, if its the cable behind the **** you have a bit more expensive problem</TD></TR></TABLE>
Right, you apparently have to pull the dash to fix that one (I've had that problem for a while but am to lazy to do it, even though my heat **** won't go all the way to the right... winters are mild here).
Your not having that one too are you?
Old May 2, 2006 | 03:43 PM
Default Re: (dmurphy2k3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmurphy2k3 &raquo;</TD></TR><TR><TD CLASS="quote">
Your not having that one too are you?</TD></TR></TABLE>
me? the whole button thing was replaced but it didnt fix it so im thinking it deff is the cable in the back for me, both ***** didnt work but the blower one started to after the replacement so that just lead me to think the heat has the cable behind it so its gotta be that. i just hope this guy doesnt have to go through all that
Old May 2, 2006 | 04:27 PM
dmurphy2k3's Avatar
My heat **** does this thing where if i put it all the way on the red side, it just slides back halfway automatically and won't stay. I was told in the past you had to pull the dash to replace it, thats what i thought you were talking about, but they sound like similar problems regardless.
love of the sol
Jul 12, 2007 03:28 PM
jlucas
Dec 2, 2005 08:15 AM
adamcinho
Feb 17, 2005 07:32 PM
Nighthawk GS-R
May 21, 2003 07:49 PM
Mr. Softee
Apr 15, 2003 01:53 AM
