del sol front conversion
Old Apr 30, 2006 | 10:04 PM
v-tecleta's Avatar
Default del sol front conversion
if i convert my del sol front to an ek or eg would i need to do any customizing?
Old Apr 30, 2006 | 10:16 PM
broketuner-Sol_Si's Avatar
Default Re: del sol front conversion (project D)
well, first off this is in the wrong forum(needs to be in the appearance forum!!!!) and most likely(only basing this on stuff I've read/heard of) yes there will be some custom work invloved(I believe the EK fenders won't bolt up right). To be honest though I wouldn't do it, you could better spend the money else where IMO.
Old Apr 30, 2006 | 11:36 PM
Out of every
just leave it alone. front ends on del sols are classics
to much work just not to look right in the end
Old May 1, 2006 | 03:13 AM
pythoner's Avatar
you would have a lt of welding and body work....don't do it below is a del sol
Old May 1, 2006 | 06:05 AM
v-tecleta's Avatar
yeah i think you guys are right.. imana keep it that way thanx for the opinions
Old May 1, 2006 | 06:06 AM
v-tecleta's Avatar
Default Re: (pythoner)
good luck on that project
Old May 1, 2006 | 07:46 AM
Out of every
Default Re: (project D)
another sol saved... woot woot
Old May 1, 2006 | 08:26 AM
imm0rt41's Avatar
Yeah, Del Sol front > * thanks for not molesting another one!
Old May 1, 2006 | 10:06 AM
sikciv666's Avatar
Default Re: (imm0rt41)
wow that rats nest on the firewall makes me cringe.
Old May 1, 2006 | 10:21 AM
MiX's Avatar
MiX
well in case you actually wanted the answer, you need the following:
del sol fenders
EK fenders
Ek headlights
Ek Hood
Ek bumper
Ek support/rad support - if you want a clean install
then you have to weld the back part of the del sol fenders to the civic fenders. thats pretty much it
You can do this for either civic or teg conversion.
Old Apr 5, 2009 | 02:03 PM
belbel's Avatar
Me personally I like the conversion
Old Apr 5, 2009 | 02:06 PM
buff1110's Avatar
i dont like front end swaps unless your putting the jdm front on
viciousvisionslarry
Aug 14, 2013 07:49 AM
9DcurlyS4
Northwest
Mar 25, 2011 10:39 PM
raidacaipo
Mar 13, 2009 06:43 AM
