Toda C's idel...
Old Apr 9, 2002 | 10:56 AM
TaboR's Avatar
New User
Default Toda C's idel...
are there anyways to get rid of the lumpy idel ??
Old Apr 9, 2002 | 10:57 AM
Mike K's Avatar
Default Re: Toda C's idel... (FreddyR)
easy.
throw 'em in a ditch and put some jun's or spec A's in.
bring it on, flamers.
Old Apr 9, 2002 | 10:59 AM
TaboR's Avatar
New User
Default Re: Toda C's idel... (Mike K)
Jun's stage 3 not lumpy at all???
B18CXr's Avatar
zero the gears
Old Apr 9, 2002 | 11:00 AM
mafay2's Avatar
New User
Lean the hell out of it!!
My spec B idle steady at around 800rpm +/- 50 all the time.
Old Apr 9, 2002 | 11:01 AM
Big Phat R's Avatar
All high-lift long duration cams will have idle characteristics that are different from the stock cam. They generally don't create enough vacuum at idle. You get power at the expense of smooth idle at 800 rpm. Usually having a slightly higher idle point say 1000-1100 will get rid of this problem.
Spec C's are some of the most aggressive cams you can buy for the Type R.
Old Apr 9, 2002 | 11:07 AM
Willard's Avatar
idle?
use stock cams
Old Apr 9, 2002 | 11:13 AM
azn98R's Avatar
JUN 3's, not much or at all... the valves were a lil louder than normal when I installed it, but when I tightened up the valves....smoooth....
but some like the the lumpy noise, I prefer it to be a silent killer. hehehe
[Modified by azn98R, 3:14 PM 4/9/2002]
Old Apr 9, 2002 | 11:34 AM
Black R's Avatar
25 Year Member
Why?
B's and C's idle the same. YUMMY! You really can't tell by listening unless you know what you're listening for.... It's a quiet little HONDA, not a V8.....
[Modified by Black R, 3:36 PM 4/9/2002]
Old Apr 9, 2002 | 12:52 PM
StinkyTofu's Avatar
Default Re: Toda C's idel... (Black R)
I think the way that the B's and C's idle is just awesome. I hope i do love the lump
Deetz
11
Dec 16, 2004 11:27 AM
TypRice
Oct 2, 2003 04:50 PM
Montreal R
Apr 2, 2002 10:47 PM
amrintegra
Dec 9, 2001 12:18 PM
itr501
Sep 27, 2001 04:01 PM
