Temperature Problems
Old Apr 30, 2006 | 09:58 PM
HondaHemi's Avatar
Default Cooling Problems
I've swapped in a Zc and my temp. guage doesn't seem to be working. I think it's overheating, but I can't tell for sure cause the guage doesn't work. When I let it warm up, I turned on the heater to full blast on hot, and it was barely warm air. Is it the thermostat??? or something else??? Oh, and the fan never turned on in all of this, but I jumped the connection for the fan switch, and the fan worked.
Modified by HondaHemi at 12:39 AM 5/1/2006
Old Apr 30, 2006 | 10:42 PM
HondaHemi's Avatar
Someone please help me. This is daily driver, and if it breaks from overheating, my dad is NOT gonnna buy me another one!
Old Apr 30, 2006 | 10:46 PM
JDM-EJ1's Avatar
Default Re: (HondaHemi)
When your car is turned on, and has been on for a little bit.. Put your hand on the top radiator hose, if it's cold that means your thermostat isn't opening and it will need to be replaced. Also, if you can, try swapping another cluster in there to make sure it's not a faulty cluster.
Old Apr 30, 2006 | 10:49 PM
HondaHemi's Avatar
i know the temperature gauge worked before I swapped the motor. And I'm almost sure that the upper hose was hot, cause i had touched it earlier today.
JDMfan77
13
Jul 20, 2010 06:30 AM
patrickstar
11
Jun 17, 2009 03:42 PM
jdm_dc_fan
Jul 28, 2008 09:59 PM
eg6.vtec
Jun 9, 2008 05:24 PM
Fighterinsnatch
Jul 20, 2007 01:27 PM
