GSR Cluster In Hatch
Old Apr 30, 2006 | 07:47 PM
92J-SpecHatch's Avatar
Default GSR Cluster In Hatch
i got a gsr cluster that im bout to throw in my hatch.. a buddy of mine has offered to wire it up for $50 though but they look sick in hatches.. what do you guys think??
Old Apr 30, 2006 | 07:53 PM
bmoua's Avatar
if you throw in a gsr cluster..you might as well throw in a ITR cluster bro...i like the gsr cluster but i love the ITR cluster...usdm or jdm....plus you'll get the amber unlike the gsr it lights up white....
Old Apr 30, 2006 | 08:06 PM
Default Re: (bmoua)
true but the jdm clusters are expensive.. how much do the jdms usually go for.. oh and the only reason i thought about doin it is because the gsr cluster was just layin in my garage
Old Apr 30, 2006 | 08:09 PM
bmoua's Avatar
Default Re: (92J-SpecHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92J-SpecHatch &raquo;</TD></TR><TR><TD CLASS="quote">true but the jdm clusters are expensive.. how much do the jdms usually go for.. oh and the only reason i thought about doin it is because the gsr cluster was just layin in my garage
you can find the jdm ones for at least 180 or below...i've seen alot of them here on HT...you hardly see the usdm ones though...they are usually more expensive...but if your koo with the gsr go for it...its still pretty cool to have a gsr cluster in a EG....
Old Apr 30, 2006 | 08:16 PM
Default Re: (bmoua)
most def.. and it got all amber bulbs in it.. so ill see waht it looks like when im done with it.. and maybe later on down the road ill get the itr one
Old Apr 30, 2006 | 10:09 PM
shyboi4u's Avatar
i have a gsr cluster in my hatch with red bulbs in them but they come out amber.
sorry, camera phone.
Old May 1, 2006 | 03:24 AM
Default Re: (shyboi4u)
sick.. did you put it in yerself?? and if you did do you have the wiring diagram??
Old May 1, 2006 | 04:29 AM
stackz's Avatar
at the jetties fishin'
Community Builder
wiring diagrams all over this site if you just search the archives.
its probably best if you search anyway since there's several people with diagrams and half of them arent correct....
the only thing on the cluster that wont work after you do the swap will be the little maintainence light/reset since it's powered by a separate module unlike inside the cluster on the civics.
I did this swap on my old 98 civic back when I had it and my LS cluster is on the way for my 93 hatch right now along with the module for the maintainence light so I'll put up the little how-to for that once I get it in.
swapping the clusters is easy if you can do simple repair stuff, but yeah, if your friend is doing it the "right" way, then $50 sounds fair considering I get $50 to put amps in cars all day long. this is about on par.
whatever you do, dont let him do it if he's gonna cut/splice wires. He should do the pin-pull method where you pull the pins out of the connectors and swap them...so you can more easily go back to stock if you change your mind later.
Old May 1, 2006 | 10:23 AM
shyboi4u's Avatar
yeah i put it in myself. all i did was look at the back of the stock cluster and followed all the wires and on the integra cluster i did the same thing. you might want to get a haynes manuel for the civic just incase. on my integra cluster i had the get the pigtail for the cluster and then all i did was extend the wires to the stock wires in the civic. i didn't tap or cut the wires on the stock harness because i might want to go back to stock so i did it the ghetto way and just stuck the wires in the stock harness. i've ran it like that for 3 years and no problems.
Here's a day shot.....
Here you go i found this for you. hope it helps...
https://honda-tech.com/zerothread?id=1053318
Modified by shyboi4u at 1:33 PM 5/1/2006
Old May 1, 2006 | 06:36 PM
thanks for all the help from all of you.. anyone else have any opinions
Old May 1, 2006 | 09:02 PM
shyboi4u's Avatar
i found the wiring diagram. did you see it?^^^
Old May 2, 2006 | 12:04 AM
UNKNOWN_MEMBER's Avatar
Something different. Only thing i don't like is how i couldn't get the clear plastic cover to fit. nonetheless i like it.
Old May 2, 2006 | 12:44 AM
riceburnerryan's Avatar
yeah i did it, if you know basica wiring, then you can do this, and you need to kinda cut the gauge bezel depending on how you do it
Old May 2, 2006 | 12:55 AM
xd69's Avatar
Default Re: (riceburnerryan)
http://hmotorsonline.com/shop/...neous
i put a gsr cluster in my ek, did the wiring my self too thanks to ht. search. you'll find everything you need here!
Old May 2, 2006 | 01:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shyboi4u &raquo;</TD></TR><TR><TD CLASS="quote">i found the wiring diagram. did you see it?^^^</TD></TR></TABLE>
yea thanks for findin it for me..
Old May 2, 2006 | 02:35 PM
shyboi4u's Avatar
n/p, just making sure you seen it. it help me out too. my srs light wasn't working and i didn't know what was the reason and i thought my bulbs just blown or something. turns out i had to switch the wire and when i found it for you that day. i went and messed with mine and now it works.
Chris.B.
Texas -OK -LA (Sales)
Jan 11, 2011 05:44 PM
vndsd1
Northern California (Sales)
Apr 14, 2010 10:50 PM
JDM-jerm
Nov 26, 2008 10:52 AM
:jdmshmaydm:
Apr 29, 2003 04:13 AM
