Check engine likght comes on at 50-60 mph or high revving
Old Apr 30, 2006 | 05:55 PM
accord_si's Avatar
Default Check engine light comes on at 50-60 mph or high revving
could this be caused due to an egr valve
Old Apr 30, 2006 | 06:03 PM
Ross 2.0's Avatar
In a Junkyard near you.
You need to pull the code 1st. What computer are you running?
Old Apr 30, 2006 | 06:28 PM
accord_si's Avatar
Default Re: (MooGoCow3)
I'm running the f22b jdm motor with the h23 ecu
Old Apr 30, 2006 | 06:37 PM
92ehatch's Avatar
Default Re: (accord_si)
does your speedo jump a little bit?
my civic did somethign similar, around high rpm and 60 mph and it would start jumping.
the code was for the VSS
you will definately need to pull the code to get a definate answer
Old Apr 30, 2006 | 06:41 PM
accord_si's Avatar
Default Re: (93cb7sedan)
I've never noticed if the speedo jumped I will def look and get the light read and what's vss
Old May 1, 2006 | 04:47 PM
92ehatch's Avatar
VSS is the vehicle speed sensor, its located on top of the tranny
Old May 1, 2006 | 08:48 PM
HONCORD's Avatar
Wont the wheel speed sensor kick on ABS light?
Old May 1, 2006 | 09:37 PM
accord-pro's Avatar
Default Re: (HONCORD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONCORD &raquo;</TD></TR><TR><TD CLASS="quote">Wont the wheel speed sensor kick on ABS light?</TD></TR></TABLE>
Nope..........it will kick on the chk engine lite and the D lite ..
accord si you need to see what code computer has stored ..read it and post it here
Old May 2, 2006 | 08:56 AM
accord_si's Avatar
Default Re: (accord-pro)
My mechanic is away for a few days so my light won't be read for a few days but also right before the light goes on the car stutters for a little bit
Old May 6, 2006 | 08:03 AM
accord_si's Avatar
hey guys went and got the code(s) checked out it threw out codes 1, 3, and 43
Old May 6, 2006 | 10:42 AM
BLKFLSH's Avatar
Codes:
#1 - ? Maybe O2 sensor ?
#3 - Manifold absolute pressure sensor
#43 - Fuel supply system
Has the fuel filter ever been changed? If you can, check fuel pressure at the fuel rail.
Old May 6, 2006 | 10:56 AM
blueshark's Avatar
Default Re: (BLKFLSH)
BLKFLSH is on the right track! Test resistance values of the HO2Sensor heater. This, If it fails, Can cause all kinds of problems.
Old May 7, 2006 | 03:43 PM
accord_si's Avatar
Default Re: (blueshark)
Hey guys replaced o2 sensor no more cel and drives so much better thanks for the help
Old May 7, 2006 | 04:04 PM
BLKFLSH's Avatar
Kooooool man
Tank_EM2
Honda Civic (2001 - 2005)
Jul 1, 2014 03:28 PM
Progen
Dec 27, 2013 02:26 AM
Mad Money
Jan 9, 2006 05:20 PM
plusONE jboy
Jan 25, 2004 05:01 PM
CaptainObvious
Aug 18, 2003 04:41 PM
