3rd gear grind
Old Apr 30, 2006 | 05:52 PM
civic16's Avatar
Default 3rd gear grind
ok i have a b16 with a s1 tranny, every time i am runnin it hard and go to put it into 3rd it like does a little grind but goes in. i am just worried i am going to mess up my tranny, how can i fix this????
Old Apr 30, 2006 | 06:07 PM
shortSHIFT's Avatar
Default Re: 3rd gear grind (civic16)
yes! ur syncro is going bad...replace ur tranny fluid w/ GM syncro mesh and double clutch 3rd gear for a couple of days! it goes back to normal for every day driving but that one time you agressively slam 3rd in a again...you get the slight grind again and have to double clutch again for a while!..........sure beats replacing syncros! be kind to the S1 dos pennys
Old Apr 30, 2006 | 06:10 PM
Twilight's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic16 &raquo;</TD></TR><TR><TD CLASS="quote">ok i have a b16 with a s1 tranny, every time i am runnin it hard and go to put it into 3rd it like does a little grind but goes in. i am just worried i am going to mess up my tranny, how can i fix this????</TD></TR></TABLE>
You cannot fix it. I'm sorry, but the old transmission's synchros arent the best ones. They start to worn out, and start the grinding. Dont worry, you can still drive it. Change your gearbox oil to prevent other gear grindings. Its not bad if it grinds only in one gear, but its bad when it does on every gear. Up and down.
When it goes really bad in future. Change your tranny to hydro- clutch type, they have little better synchros.
Old Apr 30, 2006 | 06:18 PM
civic16's Avatar
Default Re: 3rd gear grind (Twilight)
alright ill change my fluid and double clutch for a few days then see what happens, it only does it going into 3rd so i guess i should be ok for a while right?
well how long should my tranny last thou.......... its not going to go out on me any time soon is it?
Old Apr 30, 2006 | 06:21 PM
Tippyman's Avatar
Add some penzoil synchromesh.
Old Apr 30, 2006 | 08:15 PM
madmanmulligan's Avatar
Default Re: (Tippyman)
Mine does this too on my Y1 tranny. Just be careful shifting into 3rd. Double clutch in that gear and take at easy with it
Old May 1, 2006 | 09:39 AM
Twilight's Avatar
Default Re: (madmanmulligan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic16 &raquo;</TD></TR><TR><TD CLASS="quote">alright ill change my fluid and double clutch for a few days then see what happens, it only does it going into 3rd so i guess i should be ok for a while right?
well how long should my tranny last thou.......... its not going to go out on me any time soon is it?</TD></TR></TABLE>
Yeah, i think you are fine very long. If you dont push it too much. My 1st -&gt; 2nd has grinded for two years now. And i push it hard atleast once a week. So if it doesent grind on normal driving, you should be alright for few years atleast. Even more. Just change the tranny fluid to avoid other synchros go bad.
Old May 1, 2006 | 11:51 AM
civic16's Avatar
Default Re: (Twilight)
k well where would i pick up some of this penzoil synchromesh? would like the normal hardware store stock it or what?
Old May 1, 2006 | 01:46 PM
tpod's Avatar
Default Re: (civic16)
autozone carries gm syncromesh, had the same problem as you, put it in a year ago and the grind went away after about 500miles (knock on wood)
Modified by tpod at 2:58 PM 5/1/2006
Old May 1, 2006 | 02:29 PM
civic16's Avatar
Default Re: (tpod)
alright thanks guys i think ill run and get some tonite, i cant afford losing a tranny just after gettin the new b16 in.
MrExclusive
Feb 4, 2010 07:52 AM
racingcrx
Sep 25, 2006 06:03 AM
wallawee
Jul 29, 2006 05:43 PM
Integra99
May 26, 2006 10:34 AM
Bulldogg83
Apr 15, 2004 03:37 PM
