STR 68mm throttlebody lopey idle faulty tps or map?
I installed a STR 68mm TB on my 99GSR and the thing can't rev past 3500rpm. Then it shuts down. Could it be a faulty tps or map sensor? I tried using different ones but I still get the same result. Another question are OBD1 and OBD2 sensors(tps&map) the same. I'm currently using the stock TB on the blox IM. Any suggestions, holla
civicEX1995
68
Jan 13, 2012 11:15 AM
97LXF20B
Oct 8, 2007 03:42 PM
