Rear Disc swap on del Sol from 1990 integra questions
Old Apr 30, 2006 | 04:35 PM
Kod Sol's Avatar
Default Rear Disc swap on del Sol from 1990 integra questions
How do i connect the e-brake lines when i swap to disc brakes from drum? Do i have to buy anything to put this together? DO the brake lines and e-brake lines connect or are they seperate lines or cables? any help would be great
Old Apr 30, 2006 | 04:41 PM
Targa250R's Avatar
be professional
Default Re: Rear Disc swap on del Sol from 1990 integra questions (KodSol)
The fittings on both the e-brake cables and the soft lines are different for wheel cylinders vs. calipers. You'll need soft lines for a car with rear discs, and e-brake cables for a del Sol Si or VTEC.
Old Apr 30, 2006 | 04:44 PM
Kod Sol's Avatar
Default Re: Rear Disc swap on del Sol from 1990 integra questions (Targa250R)
So these lines and cables i can probably pick up from someone on HT or should i buy them new? and where would a good place to buy them at?
Old May 1, 2006 | 01:29 AM
BlueIntegraBoy's Avatar
Honda dealership. It's good to buy ebake cables new, they are not too expensive. For the soft lines, you can invest in stainless steel lines. I don't see too many used brake lines. If not, buy them new at Honda as well.
Old May 1, 2006 | 05:15 PM
Kod Sol's Avatar
Default Re: Rear Disc swap on del Sol from 1990 integra questions (BlueIntegraBoy)
thanks for the information, it will soon be swapped.
mugen_sol
Jul 29, 2015 10:57 AM
KodSol
Apr 10, 2007 01:10 PM
Kod Sol
Jun 21, 2006 07:27 AM
gakkuken
Mar 1, 2005 01:03 AM
AzntaggeR
Aug 17, 2003 06:02 PM
