Less than 10K mi on new suspension...and already a blown Koni!!!
Old Apr 30, 2006 | 03:06 PM
KOALA YUMMIES's Avatar
Default Less than 10K mi on new suspension...and already a blown Koni!!!
So a couple months ago I put together some Ground Controls (400lbsin F, 500R), the Ground Control upper mounts, and some Koni Yellows that I purchased brand new. The car isnt even close to being slammed (at least a 2 finger gap) been tracked 3 times since then and less than 10K miles total on the whole setup. Never the less I pop the hood to see this:
Fresh oil leaking from the top adjustment **** all over the upper mount...
After doing a lot of reading and researching I thought this setup would be the way to go, didnt know I'd have the fun to tearing it all down, lose the suspension settings and have to get another alignment after 10K...
Old Apr 30, 2006 | 03:16 PM
andyt's Avatar
Default Re: Less than 10K mi on new suspension...and already a blown Koni!!! (neo_)
Konis are lifetime warranty, right?
Old Apr 30, 2006 | 03:18 PM
jetydosa's Avatar
25 Year Member
That sucks, but they should warranty that for you. PM user CRX Lee and see what he recommends you do (he works for Koni).
Old Apr 30, 2006 | 03:24 PM
ecahatch's Avatar
Senor Miembro
Default Re: Less than 10K mi on new suspension...and already a blown Koni!!! (KOALA YUMMIES)
nice......i guess i should start on trying to get a new one, cuz my pass rear has some oil like that....but not that much.
Old Apr 30, 2006 | 04:30 PM
PrinceAli132's Avatar
Did you get the koni's revalved?
Im not 100% sure about this, but aren't the off the shelf Koni's only rated for 400lb spring rates. Again, im not sure, so if someone can correct me if im wrong.
Ali
Old Apr 30, 2006 | 04:31 PM
white rocket's Avatar
Default Re: Less than 10K mi on new suspension...and already a blown Koni!!! (ECAhatch)
******' bogus . I wonder what could of caused it to leak. Just a fluke maybe? I'm sure it's under warranty but still, kinda of a let down. Let us know how you make out
EDIT: the KTeller8 Koni sale thread made me think of this thread. It's titled "Koni yellow blowout"
Old Apr 30, 2006 | 04:41 PM
s2kdre's Avatar
Default Re: Less than 10K mi on new suspension...and already a blown Koni!!! (white rocket)
damn its been 5 years for me and i never had a prob yet, thats weird.
Old Apr 30, 2006 | 04:43 PM
jetydosa's Avatar
25 Year Member
Default Re: Less than 10K mi on new suspension...and already a blown Koni!!! (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">
Ali</TD></TR></TABLE>
They will handle more than that, although around that is kind of a rough guideline.
My non-revalved yellows took 600lb springs and ~30 autoxes, and 2-3 track days w/o any issues.
Old Apr 30, 2006 | 05:11 PM
Jet Phi's Avatar
Default Re: Less than 10K mi on new suspension...and already a blown Koni!!! (jetydosa)
damn that sucks . . . they are warranty right?
Old Apr 30, 2006 | 05:54 PM
The warranty works with a copy of the original receipt (which was back last July), and a copy of the vehicle registration...
Other than that I believe they are still covered but still the downtime sucks.
Old Apr 30, 2006 | 08:17 PM
nholmes's Avatar
Unfortunate side effect of mass production. It happens to the best of them though.
Sucks at any rate...
Old Apr 30, 2006 | 09:48 PM
warwagon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">The warranty works with a copy of the original receipt (which was back last July), and a copy of the vehicle registration...
Other than that I believe they are still covered but still the downtime sucks.</TD></TR></TABLE>
thats why my receipt is in the glove box... just in case
Old Apr 30, 2006 | 10:01 PM
92TypeR's Avatar
FSAE
Default Re: Less than 10K mi on new suspension...and already a blown Koni!!! (warwagon)
While they are out, I would recommend getthing them revalved.
My revalved yellows have a couple dozen track days, and just over 40k miles. No complaints at all
Old Apr 30, 2006 | 11:03 PM
niterida's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetydosa &raquo;</TD></TR><TR><TD CLASS="quote">They will handle more than that, although around that is kind of a rough guideline.
My non-revalved yellows took 600lb springs and ~30 autoxes, and 2-3 track days w/o any issues.</TD></TR></TABLE>
I am pretty sure that those rates are at the very upper limit of the valving of the shocks, especially the 500lb/in
But I have 650lb/in on non-valved ones too and they have done many track days. But I have been told that they will eventually blow with rates that high.
Maybe we just got lucky?
Old May 1, 2006 | 01:54 AM
cquence's Avatar
ouch! I just got my self koni neuspeed yellow shocks too and this is a scary sight to see.
hope you get them replace through warranty
BTW I called koni North America before buying my Yellows and the service rep said that the off the self yellows are rated at 500-550 lb/in the front and 550-600 lb/in.
Old Aug 11, 2006 | 10:36 AM
Fuster_Cluck's Avatar
What's the latest on your blown shock & lifetime warranty?
I just ordered the same set-up.
Old Aug 11, 2006 | 12:27 PM
GUILOTINE's Avatar
Kill Gil
Tein &gt; Koni
Old Aug 11, 2006 | 12:33 PM
My95SlvrBlt's Avatar
Default Re: (GUILOTINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUILOTINE &raquo;</TD></TR><TR><TD CLASS="quote">Tein &gt; Koni </TD></TR></TABLE>
right...
Old Aug 11, 2006 | 12:37 PM
GUILOTINE's Avatar
Kill Gil
Default Re: (My95SlvrBlt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My95SlvrBlt &raquo;</TD></TR><TR><TD CLASS="quote">
right...</TD></TR></TABLE>
well I've never had any problems on any sets of the Teins I've owned and tracked
HA's, RA's, and RS's
The new Circuit Matsers or N1's are next on the list
Old Aug 11, 2006 | 12:38 PM
Maybe I should clear... Reliablitly wise, I've personally never first hand seen a failure of a Koni, nor a Tein. Both are of extremely high quality.
Truth is, not everything is perfect, if everything was perfect Auto technicians would have no job, and neither would half of the rest of the world.
Old Aug 11, 2006 | 12:40 PM
GUILOTINE's Avatar
Kill Gil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My95SlvrBlt &raquo;</TD></TR><TR><TD CLASS="quote">Maybe I should clear... Reliablitly wise, I've personally never first hand seen a failure of a Koni, nor a Tein. Both are of extremely high quality.
Truth is, not everything is perfect, if everything was perfect Auto technicians would have no job, and neither would half of the rest of the world.</TD></TR></TABLE>
I agree
Old Aug 11, 2006 | 12:48 PM
Tweakmeister's Avatar
Sorry to hear - could've been a bad piece of metal internally or something.
In my chats with CRX LEE (great guy btw), he mentioned the failure rates on these is incredibly low. With the same setup as you, and 5 years on the clock, he wasn't worried about mine having any significant wear.
As a side note...
For those considering revalving, he also mentioned to check your ride height, as riding on the bump stops can cause bumpiness (and not a sign of a "blown" shock).
Old Aug 11, 2006 | 01:06 PM
GUILOTINE's Avatar
Kill Gil
Default Re: (Tweakmeister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">As a side note...
For those considering revalving, he also mentioned to check your ride height, as riding on the bump stops can cause bumpiness (and not a sign of a "blown" shock).</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Koala Yummies &raquo;</TD></TR><TR><TD CLASS="quote">The car isnt even close to being slammed (at least a 2 finger gap)</TD></TR></TABLE>
Old Aug 11, 2006 | 01:54 PM
uNF$@#!'s Avatar
your standard koni that isnt revalved imo isnt up to spec to what a lot of the owners here with revalved konis are telling you what it can handle.... i never had first hand exp but i think out the box they arent valved for high rate springs, 400/500 being close to what i'd throw on.
for that reason i decided to go with bilsteins (plus they were much cheaper for me to get - about 50% the cost ) I also am using 400/500 GCs.
im sure my bilsteins may/may not go but i've been happy with the setup and it handles 400/500 just fine.
tein shocks, i've heard of mixed reviews, depending on the model, but for the most part alot of the cost involved with the tein shocks/setups are from the jdm blingage i reckon.
Old Aug 13, 2006 | 07:05 PM
As a side note...
