GSR Cluster swap does NOT require the plugs to be swapped
Old Apr 30, 2006 | 02:06 PM
Crackerballer's Avatar
Default GSR Cluster swap does NOT require the plugs to be swapped
Ok, so I have a 94 RS with a B18C1 in it, and I just picked up a GSr gauge cluster off a member here. I swapped out the clusters and everything works except the fuel gauge and the ABS light stays on constantly. So I pulled out the 94-97 helms on PDf, and found out what wires went into which banks of the plugs.
Here is how I solved the problems:
1: Pull the ABS bulb out (because I have no ABS) and BAM! no more ABS Light
2: On the 94-97 Harnesses, the fuel wire is a white and yellow wire (just like on the 98+) and is on Bank B3 of the right hand plug (consult helms for pictures) On the 98+ GSR cluster, it needs to be in B1.
Swap banks B1 and B3 wires, because B3 is empty on the 98 GSR plug.
So far, I know the Tach, Speedo, Temp, Check engine, SRS, Turn signals, fuel, Bright light indicator, and open door lamps work.
YOU WILL LOSE YOUR SEATBELT LAMP. If this bothers you, then consult a 98+ and 94-97 helms, figure out what wires go where, and convert your entire plugs over.
I AM NOT RESPONSIBLE FOR ANYONE MESSING THEIR CRAP UP. I am just letting everyone know what has worked for me
Old Apr 30, 2006 | 02:19 PM
IHTFP's Avatar
Default Re: GSR Cluster swap does NOT require the plugs to be swapped (Crackerballer)
good info...
Old Apr 30, 2006 | 02:51 PM
I am sure there are plenty of people on here who already knew this, but I imagine there are many more who don't. I just figured it would be good to post since like 900 people tried to sell me plugs when I was searching for a cluster.
Old Apr 30, 2006 | 04:54 PM
96 GSR-T's Avatar
Default Re: (Crackerballer)
I tried to put an 00 R gague cluster in my car and had the same problem... i was just told to swap out the fuel gague from my GSR cluster to the R cluster, is that possible?
Old Apr 30, 2006 | 05:16 PM
blkb18's Avatar
i am swapping my gsr cluster into my LS, but they are both 96's, so I will be ok i assume. Good info I was wondeing.
Old Apr 30, 2006 | 05:22 PM
96 GSR T, I am not sure about the Type R cluster. That does make sense, but something makes me think that just swapping out the fuel gauge won't matter, because the board on the back determines what signal goes where. If the signal is not getting to the gauge correctly, the gauge won't work. Check out the Helms Manual for 98+ and see what it says about the type R cluster.
blkb18 you should be fine.
Old May 1, 2006 | 01:33 AM
BlueIntegraBoy's Avatar
You don't have to lose your seatbelt light. Check the link in my signature for the wiring diagram. You have to switch the wire for the seatbelt as well.
Old Mar 15, 2008 | 01:19 PM
kandyeghatch's Avatar
Default Re: GSR Cluster swap does NOT require the plugs to be swapped (BlueIntegraBoy)
i need some help with the cluster swap any one kan help
Old Mar 15, 2008 | 02:29 PM
Default Re: GSR Cluster swap does NOT require the plugs to be swapped (kandyeghatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kandyeghatch &raquo;</TD></TR><TR><TD CLASS="quote">i need some help with the cluster swap any one kan help</TD></TR></TABLE>
What do you need help with?
Old Mar 15, 2008 | 02:39 PM
yc_dc4mar's Avatar
idk everyone makes a big deal about this. its not that hard. if your new cluster has issues you just switch the gauges. end of story.
CO671
12
May 8, 2012 02:57 AM
dohcgarage@714
Jan 3, 2008 05:31 PM
Honda_RN
Nov 15, 2004 01:17 AM
-iLLuZioN-B18C1
Mar 7, 2003 06:18 PM
