Installed '98 CRV Cluster into '99 Civic; some questions/concerns...
I didn't expect it to be so easy; just ripped out an Automatic 1998 CRV Cluster and put it in my Standard 1999 Civic DX (d16y7). I got some questions though...
-Is my idle too low? (approximately 500rpm)
[The view may seem parallax but it is around 500RPM when I took the picture]
-Why am I getting an ABS light?
-Since the CRV has a larger fuel tank than the Civic; is it unlikely for my fuel gauge to reach FULL?
(Pulled CEL codes a while ago, it's for my o2 sensor; ordered them already)
Ek Forever y0!
Re: Installed '98 CRV Cluster into '99 Civic; some questions/concerns...
You're getting the ABS light probably because you plugged in the yellow plug. Only two of the plugs should go in:
1) The long one over the top and center of the cluster
2) The ~1.5" long one that goes over the tachometer.
Leave the yellow unplugged.
The 2 blue plugs that go on the outer edges of the cluster; the yellow one you mentioned and an orange one hanging in the dashboard.
edit: I left the orange one out; kept the 2 blue ones and yellow one in; ABS light is gone.
Pics of this cluster lit up? I wanna see how it looks plannin on gettin one as well did it just drop in or did you have to modify anything?
...speedometer wasnt working so I tapped the cluster. Then the needle broke .
Now I put back in my Civic cluster and the speedometer on the Civic cluster isnt working....ugh
same thing happened to me I switched my dx cluster out for an ex cluster and the speedometer stopped working for both
......let me know what you find out
EXTRA gay when i did my swap it plug in but the stuipd empty tank light came on even with a full tank of gas and my srs is on as well i dont know why
Yeah; a standard CRV Cluster would be amazing too though. If the orange was maybe white, red, would look much cleaner.
edit: UPDATE. Bought a new CRV (Automatic) Cluster from a local salvage yard for $60.
1998 CIVIC ex auto with a 1999 crv cluster idk why the fuel light is on am thinking bye bye blub but the srs am worried about
utturkey
05-25-2011 05:42 PM
skeeterDX
03-06-2005 08:35 PM
