SRS Light Trouble Codes - Lets get some info on them....
Guys there is a serious lack of info on srs codes for preludes, and the helms is no help due to the fact that it requires you to buy the test connector from honda. A list of the flashed out codes would be wonderful.
To get the codes out, you just jump the same connector that you would to read CEL codes.
Thanks in advance for anything you guys can contribute, maybe like if civic codes are the same and all.
Thanks
Matt
Thanks
Matt
11 Open in the driverside air bag inflator
12 short between wires in the driverside air bag inflator
13 short to power in the driverside air bad inflator
14 Short to ground in the driverside air bag inflator
21 Open in the passengerside air bag inflator
22 Short between wires in the pessengerside air bag inflator
23 Short to power in the passengerside air bag inflator
24 short to power in passengerside air bag inflator
51 interfailure of the SRS unit
91 Faulty srs indicator light curcuit
92 Faulty srs power supply system
101 srs unit replacement code
I will get more tomorrow at owrk if you remind me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">I'll bump it tomm. if nobody else does....thanks for the info man....</TD></TR></TABLE>
If you can, shoot me a PM, it is hard to check the threads at work, if you do not mind.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">my bro's civic is running strong btw
Sorry?
</TD></TR></TABLE>Sorry?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer »</TD></TR><TR><TD CLASS="quote">If you can, shoot me a PM, it is hard to check the threads at work, if you do not mind.
Sorry?</TD></TR></TABLE>
yeah ill pm you....my brother bought that grey h22 civic hb you tuned.....think the guys name was ricky.....
oh yeah, isnt the light supposed to flash when you jump the same connector that flashes CEL codes?? i just did that and it didnt flash at all....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">oh yeah, isnt the light supposed to flash when you jump the same connector that flashes CEL codes?? i just did that and it didnt flash at all....</TD></TR></TABLE>
No, it is a yellow connector under the driver side dash
You do a power steering rack or the car in a accident before?
well guys i figured my problem out, if you ever change the spool, make sure to line the arrow straight up and have the yellow dot on the bottom left in the indicated spot.....about two turns back from full clockwise
to do the memory reset, you use the 3 pin connector under the radio
Are the SRS codes the same for Accords as the Prelude? I have a 22 DTC reading for a 96 Honda Accord. One site said this meant "Increase resistance on passenger airbag inflator."...whatever that is!
